Amazfit GTS vs GTR - Which is Better?
smartwatchse
Post by smartwatchse »
The newly released Amazfit GTS is about same price as the GTR released last year. Both are fitness focused with 12 preloaded sport modes in each. Inbuilt GPS is also present on each of these two for position and location tracking. While the GTS takes inspiration from the design of the Apple Watch, the GTR takes the appearance of a traditional watch. Its a fine classic smartwatch thanks to the ceramics bezel.
Amazfit GTS vs GTR - The Difference
Amazfit GTS
43.25 x 36.25 x 9.4 mm
24.8 grams
1.65 inch
14 days battery life
Amazfit GTR
47.2 x 47.2 x 10.75 mm
36 grams
1.39 inch
24 days battery life
The main difference between these two is that the GTR has a longer battery life and a circular shape compared to the GTS which is rectangular. Moreover, the GTS is a slightly slimmer and weighs a little less than the GTR, thanks to the aluminum case material. Although the GTR is also available in aluminum material, it's a little heavier.
The GTS with a bigger 1.65 inch display will allow you see more at a glance compared 1.39 inch GTR. Moreover, the GTS with editable display, features about 17 editable widget areas that allow you choose your preferred complication to grace the display.
Amazfit GTS vs GTR Which is BETTER?
Although the GTR has a longer battery life, each of these two is a fantastic smartwatch. Personally, I choose the GTS, its slimmer and sleeker, has a larger and brighter display while also having a long and impressive battery life.
VSparxx
Post by VSparxx »
They both are s**t, speaking from first hand experience.
karanprakash
Post by karanprakash »
Thanks for this information.
