How to install watch faces
freekshow
Post by freekshow »
I am on mobile version of the site and can't find anywhere on how TO INSTALL the watch faces ! So many great watch faces here but don't know how to get them on the watch...thanks for any help
AlexFreire
Post by AlexFreire »
Hi.
I don't know if installing watch faces on the Pace works the same as in the Stratos, but when you connect it with your PC via USB, you can access a folder inside its internal memory called "Watch faces". Just put the downloaded .WFZ file inside of it and it should appear as an option on the carousel.
I hope this helps.
simarilon
Post by simarilon »
Hi @all,
I am right now in holidays without any PC with me. Is there any other possibility to install watch faces with the Android phone? I had to factory reset my watch and lost my beloved watch face ...
osmat
Admin
Has thanked: 35 times
Been thanked: 73 times
Post by osmat »
Unfortunately for today there is no way to set the dial without turning the clock on to the computer. Our team is working on a solution. When we have the result, we will necessarily share it with everyone.
osmat
Admin
Post by osmat »
simarilon
Post by simarilon »
Hello @osamat,
thanks for the App, great :-)
Unfortunately the app is not working.
After installing the app says "not installed".
I downloaded the app 3 times but always with the same problem.
I have a Huawei Mate 10 pro.
Best regards
osmat
Admin
Post by osmat »
Before installing, uninstall the official application Amazfit
simarilon
Post by simarilon »
Thanks @Osamat. Works like a charm.
This is really a great help.
Now I have my beloved watchface again.
Without the use of a laptop or PC.
Incredible how fast you helped with this.
Best regards
Simarilon
messe34
Post by messe34 »
lüften saat arayüzlerinde osmat.mcneff.gurt ve tomomik arkadaşlarımız gibi saat de saniye de çalışsın ve maistersinger nomos mondiene ve montblanc da saniyesi çalışan yüzler bekliyoruz
messe34
Post by messe34 »
Let the hours work in seconds like osmat.mcneff.gurt and tomomic friends in the clock interfaces and maistersinger nomos mondiene and montblanc also expect the second running faces
messe34
Post by messe34 »
Let the hours work in seconds like osmat.mcneff.gurt and tomomic friends in the clock interfaces and omega maistersinger nomos mondiene and montblanc also expect the second running faces
