Hi guys, Im looking forward to the GTS since i killed my Bip by swimming in the sea. I have a few questions.
Can i use the MiFit app or do i have to use the Amazfit app? If not, do you think the MiFit app will support the GTS one day?
How can i create custom watch faces for the GTS? (I have a good knowledge in design and UI)
Any help will be appreciated.
Thankstweakbox
- Amministratore
Amazfit GTS to-be user, need help.
Meilhin
I can't dowload ,when i press dowload it automatically run out from app .please help me. My phone is oppo reno
- chm
- Has thanked: 2 times
- Been thanked: 12 times
- Contatta:
As for now - no. Only Amazfit has GTS as a device to connect.JohnMajor ha scritto: 09 dic 2019, 17:33Can i use the MiFit app or do i have to use the Amazfit app? If not, do you think the MiFit app will support the GTS one day?
But Amazfit app is almost identical to mifit.
Hard to tell if they gonna add it, as even GTR is still not in mifit.
They might want to seperate xiami and amazfit, but that is just my guess.
There are few beta versions out I think.JohnMajor ha scritto: 09 dic 2019, 17:33How can i create custom watch faces for the GTS? (I have a good knowledge in design and UI)
One working bin "unpacker" I know of is from some Portuguese group (i think - sorry if I am wrong).
Then probably someone would have to add it to well known html watchface editor: https://amazfitwatchfaces.com/editor/wa ... ditor/?bip
I will try to pack it into single package today or tommorow and put here soon cause for now it seems like some "donate to create watchface" thing is considered as only working editor for GTS.
