New version = unable to load half the watchfaces
Bloccato
Giobatta65
Messaggio da Giobatta65 »
Ht guys
first of all ... sorry for my english, hope this is the right place of the forum :)
I've used the Amazfit tool a lot when only three faces are available (and only the orange one was changeable), now I have an huge problem (please dont ask me to reinstall, reset the watch etc, I'm a programmer and I've have done all the possible steps): about half or more watchfaces are useless, I mean:
download one -> select the target face -> sync it (and I wait..I wait...) sync stops ok, the face is not present (the clock revert back to the first preinstalled "digital" face, there is the usual second analog face ... and nothing else).
I repeat: this happens on, at least, half the faces for Verge Lite (a lot in the top ten, btw).
After installing all the 11 or more faces included in amazfit I have tried manually (android -> com.huami ... etc etc) to replace with the same name (a procedure that worked fine when AmazFit contained only five faces) : same result, I click on one face in AmazFit and it revert (without any error) to the first face.
I was unable to establish where is the problem because a lot of simple face (no distance and so no) have the same problem, it... its just seems the clock refuses the .bin file after the sync (or the manual copy ... renamed of course), I dont think its a language problem because I loaded some russian faces (my Xiaomi is in italian).
As an example the clock sync (but dont load) the latest "NightLights_rus", a lot from fx_advanc (except "Tech_ORG" wich works fine) and other "big" authors here (afwafwafw and so on: I like a lot "Digit All Yellow/Cyan VL" but Im unable to see it).
Can anyone help me? No one with the same "error" (there are not error: bin files are in the folder, but only four on twelve are loadable).
Thanks in advance
Giovanni
PS THIS HAPPENS AFTER THE LATEST DECEMBER UPDATE OF AMAZFIT (I think it was updated a couple of dats ago).
Giobatta65
Nevermind ... now its working, it happens an unexplicable stuff: I (again) deleted and reinstalled AmazFaces app.
At this point the bottom list of native wathfaces (these ones coming with AmazFit app) was reversed (the list begin with the last "petals" and end with the first face),try to replace and now it works .... a mistery (first because the list is in reverse order, second because I reinstalled the app at least three times and only now I see the list in reverse... but working).
Reverse order is not a problem so ....
sorry to borher you and keep up your amazing job!
Giovanni
Bloccato
Torna a “Closed topics”
