- Administrador
Update error released today (AmazFaces app)
berilopassos
- Registrado em: 07 Out 2019, 16:11
- Contato:
After today's update, when I am going to change a face of my Amazfit GTR, Mi Fit is shown instead of Amazfit GTR and it is not possible to change the face.
Can anyone help? Is there any solution?
same problem here, I cannot change any watchface anymore after the update.
watch is uploading (opens the amazefit app despite the message that it will open the FIT app)
So I can choose a watchface in the amazfaces app, I select the watchjface that has to be replaced (new) and then uploading starts, so far so good, after finishing only the default 2 watchfaces are shown. I have the GTR 47mm, but also on my wifes watch (GTR 42 rose) it is not working anymore, please fix this!! loved the app
gr bas
gr bas
Drifter530
- Registrado em: 27 Nov 2019, 20:29
- Contato:
i m having the same problem after update....pls resolve it as soon as possible..GTR 47MM
KAIZERTONIO
- Registrado em: 26 Set 2019, 16:35
- Contato:
Hi Evebody,
The same problem. GTR 47mm
I try many things ( reset the watch, reintall the MI FIt app etc..)
Thanks,
Thanks,
Yes.
1, download or replace the file from AmazFaces
2, Find the file on your mobile.
for example - eng47_green_steps-108267-64685d93c5.bin
3, Run the file (in file manager) / have installed Notify & Fitnes for Amazfit.
... uploading takes a long time (5 minutes)
Hi all, I'm having the exact same issue. Was working fine for weeks before today
- GIK-Team
- root
- Registrado em: 22 Mar 2018, 10:00
- Has thanked: 1151 times
- Been thanked: 278 times
- Contato:
MI Fit does not have GTR supportKAIZERTONIO escreveu: 04 Dez 2019, 11:02Hi Evebody,
Thanks,
- Stas
- Registrado em: 22 Jan 2019, 21:18
- Has thanked: 4 times
- Been thanked: 34 times
- Contato:
Hi KAIZERTONIO, you are using Mi Fit for the watch?
Thanks,
Just to explain the issue in more detail.
The Amazfaces app used to work perfectly with the GTR and the Amazfit app.
From yesterday however, this is no longer the case. When hitting the download button in Amazfaces, there is no longer an option to select the Amazfit app, instead it defaults a reference to Mi Fit, and therefore when you try and sync from the Amazfit app, it doesn't work and the original default factory watch face appears instead.
Quando vou alterar uma face do meu Amazfit GTR, o Mi Fit é exibido em vez do Amazfit GTR e não é possível alterar a face.
Alguém pode ajudar?
Alguém pode ajudar?
Mrcappelle
- Registrado em: 16 Out 2019, 20:57
- Contato:
Hey guys!
I'm here because i had the same problem, in my case the Amazfaces app just force closes when selecting download, i installed the app notify and fitness and in the app i could choose a .bin file to upload as a watchface!
greetings Gilles
greetings Gilles
cozzibr.it
- Registrado em: 28 Ago 2019, 14:07
- Contato:
I also try many things ( reset the watch, reintall the MI FIt app etc..) and nothing.
It doesn't work anymore...
- osmat
- Admin
- Registrado em: 22 Mar 2018, 10:09
- Has thanked: 35 times
- Been thanked: 73 times
- Contato:
GTR do not work Mi fit use Amazfit app.
Install the latest beta version of AmazFace.
Attention
Attention
Having same problem with my stratos. Is there any solution??
- osmat
- Admin
- Contato:
What is your specific problem? Do you have Stratos or Stratos 3? Describe in full your problems, we will try to help you.ygurdag escreveu: 26 Fev 2020, 05:45Having same problem with my stratos. Is there any solution??
Quem está online
