Watch faces creation tool “GT Dial Master”
Has thanked: 1182 times
Been thanked: 281 times
Author’s website: http://www.zeeyv.com/index/gtHelper.html
This tool is suitable for the following watches models:
  • Honor Watch Magic
  • HUAWEI Watch GT
  • HUAWEI Watch GT2
The program has an interface in English and Chinese languages.
For a quick start in creating your first watch faces, we recommend you to take the following steps:
  • choose the design and elements that will be displayed on the watch face;
  • create images of the elements of the watch face based on the requirements (see the table);
  • open the tool and fill in the parameters of the new watch face (see the screenshot).
screenshot 1
In the top menu, click +Image. In the right column elements settings will appear.
  • add a picture;
  • in the XY fields indicate the location of the element on the canvas;
  • use the arrows to move the element through the layers.
screenshot 2
n the top menu click +Date and a new layer will appear in the right column.
Here you can choose any of the interactive elements such as: time, pulse, steps, weather. You can also set the font, its size, color and other parameters.
screenshot 3
Table: Component type
Type Remark Param
Image Show a image XY,Image
Percent data Show a picture base on percent;
Or show a angle by percent
XY,Image,Angle,Width
Number Show a digital value XY,HW,Color,Align
Sequence image Show one image in a sequence.
Example: there are 7 images in week, you can show one.
XY,Images
Table: Component list
Type Description Count Start Resource Remark
Percent data Second percent Suitable for sequence pictures sec.png With 60 seconds as 100%, the current second as a percentage of 60 seconds
Minute percent   min.png With 60 minutes as 100%, the current minute as a percentage of 60 minutes
Hour 12 percent   hour.png With 12 hours to 100%, the current clock is the percentage of 12 hours.
Date percent   date.png With 31 days as 100%, the current log accounts for 31 days as a percentage.
Week percent   week.png With 7 days as 100%, the current week as a percentage of 7 days
Power percent   power.png With 100% electricity, the current actual electricity accounts for 100% of the total.
Heart rate percent   heart.png With a maximum heart rate of 255 to 100%, the current actual heart rate is the percentage of 255.
Calorie percent   cal.png Calorie target converted by the number of steps obtained from APP is 100%. Current calorie value as a percentage of target value is calculated as 100% over 100%.
Standup percent   stand.png The target number of standing times is 12 to 100%, and the percentage of current standing times to the target number of standing times is more than 100%.
Strenth percent   str.png The target of medium and high strength is 30 to 100%, and the current percentage of medium and high strength time in medium and high strength target is 100% when it exceeds 100%.
Step percent   step.png The number of steps obtained from APP is 100%, and the percentage of actual steps in the number of steps is 100%.
Vo2Max percent   vo.png The maximum oxygen uptake was 80 to 100%, and the current maximum oxygen uptake data accounted for the percentage of the maximum.
Number Step number     Step number
Calorie     Calorie
heart rate     heart rate
Heart rate max     Maximum heart rate
Heart rate min     Minimum heart rate
Medium and high strength time     Medium and high strength time
Temperature     Temperature, automatically switching Celsius Fahrenheit with settings
PM2.5     PM2.5
AQI     Air Pollution Index
Pressure     pressure
Altitude     altitude
Power index     Electric quantity
Number of Standing     Number of Standing
Maximum oxygen uptake     Maximum oxygen uptake
date     date
month[text]     Month
Sequence image AMPM 2 pm 0:am 1:pm
month 12 month 1:january 2:february
Week 7 week 1:Monday 2:Tuesday
Weather 11 weather 0:unkown1:sunny_day2:sunny_night
3:overcast4:cloudy5:rain6:thunder
7:snow8:dust_storm9:hazy 10:forg
Power image 11 power 0-10, which means 0%, 10%, 20%, 30, respectively. 100%
Heart rate area 6 heart Heart rate area.
Message reader 2 msg Whether there is only news; 0 no, 1 yes;
Temperature type 2 tempt 0 degrees Celsius, 1 degrees Fahrenheit
Step 1 10 step Number of steps
Step 2 10 step Step Dozens Number
Step 3 10 step Step Hundred-digit Number
Step 4 10 step Step thousands of digits
Step 5 10 step Steps in tens of thousands of digits
12 Hour HIGH 10 time Ten-digit hours (twelve-hour system)
12 Hour LOW 10 time Ten-digit hours (twelve-hour system)
24 Hour HIGH 10 time Ten-digit hours (24-hour system)
24 Hour LOW 10 time Ten-digit hours (24-hour system)
Hour HIGH 10 time The 10-digit value of the hour, according to the system settings to determine the 24-hour system or 12-hour system
Hour LOW 10 time The 10-digit value of the hour, according to the system settings to determine the 24-hour system or 12-hour system
Minite HIGH 10 time Ten-digit value of minutes
Minite LOW 10 time Number of minutes
Second HIGH 10 time Ten-digit number of seconds
Second LOW 10 time Number of seconds
Date HIGH 10 time Date high
Date LOW 10 time Date lows
Link to the last tool: https://drive.google.com/drive/folders/ ... NFNHnDXc2J
75Krystek
Post by 75Krystek »
wyskakuje błąd pomocy jak to zainstalować
75Krystek
Post by 75Krystek »
I get an error on how to install it
