Watchface tool
Buoncuo
Watchface tool
Post by Buoncuo »
When the watchface tool will be released?
I can't wait to make new Watchfaces :mrgreen:
gj21cn
Post by gj21cn »
KoltesPunti
Post by KoltesPunti »
gj21cn wrote: 15 Nov 2019, 08:29
THANKS :D
sadly its only in chinese, very hard to understand whats going on!
There are already hundreds of watchfaces out there on their app :O
Pinkabou
Post by Pinkabou »
KoltesPunti wrote: 15 Nov 2019, 12:20
THANKS :D
OK, I have the services app, the watchface editor, and now?
I want to modify a GTS watchface, I have the .Bin files donwload from amazfitwatchfaces website (one of yours)
dpassaggio
Post by dpassaggio »
with the Chinese app you can't load a bin file, but you can only edit the faces in the service; go to the sub-folders and edit the templates directly and then load the pieces with the editor
Alecaroni
Post by Alecaroni »
dpassaggio wrote: 28 Nov 2019, 14:44
Di che cartelle parli? Parli dell'applicazione o dell'editor per Windows? Perché a me il tool sul PC non funziona, il file service.exe non si apre
dpassaggio
Se il service.exe non funziona probabilmente c’è stato qualche problema nel download e dovresti riscaricarlo; in ogni caso il programma service non ha un interfaccia grafica ma rimane in funzione solo sul prompt dei comandi, e va tenuto avviato prima di aprire il file editor.exe.
Per quanto riguarda i template modificabili li trovi cercando nella cartella service e poi nelle sotto cartelle , ogni face è divisa in cartelle separate che hanno nomi Unicode
JokerMain
Post by JokerMain »
The chinese tool is asking to pay in order to use the watch face I created, is there a way to bypass the payment and use the watch face i created for FREE??
dpassaggio
JokerMain wrote: 01 Dec 2019, 01:50
no, this is the only solution at the moment.
ps. for those who have problems with the Chinese language, I leave this link with a photo guide for creating faces
https://c.mi.com/thread-2446766-1-0.html
Boon011040
Post by Boon011040 »
Who know how to donate app with paypal ??
GTS tool can't download bin file ,In app have Sync by bluetooth only
