Page 4 of 9
Posted: 09 Sep 2019, 07:17
by lumenvindex
WF_Builder 1.0.4
- WFB_104_2.png (88.5 KiB) Viewed 671148 times
1.0.3
1.0.2
1.0.1
1.0.0
0.9.8
Fixed some bugs
0.9.7
0.9.6
WF_builder allows you to change all known parameters of a watchface. It shows how watchface will look like with different data on it. Program uses Mi Band 4 WF Tool for packing\unpacking watchfaces and has it inside Lib subdirectory. Lots of thanks to
@lvpokka for this tool.
- WFB_103_2.png (66.52 KiB) Viewed 672173 times
- WFB_102_2.png (97.89 KiB) Viewed 672586 times
- WFB_101_2.png (66.42 KiB) Viewed 673761 times
- WFB_100_2.png (95.65 KiB) Viewed 674037 times
- WFB_098_2.png (83.54 KiB) Viewed 674203 times
- WFB_097_2.png (71.41 KiB) Viewed 674852 times
- WFP_096_2.png (132.52 KiB) Viewed 675844 times
- WFB_095_1.png (57.03 KiB) Viewed 676676 times
Re: WF_Builder (watchfaces for Mi Band 4)
Posted: 27 Oct 2019, 08:05
by lumenvindex
Added WF_Builder 1.0.4 download link to the original post. Hope it will make your work more comfortable.
Posted: 03 Nov 2019, 07:21
by franluciani
Hi, anyone know how to assign hour by hour an image? I say:
When "ten" value 1 and "ones" value 1, take this image for "ten".
But when "ten" value 1 and "ones" value 2, take this other image for "ten".
It is to put the number more to left or right when the number 1 is in the clock.
I'm creating the faces of apple watch and the only thing that left is it. Please if anyone know tell me.
Posted: 03 Nov 2019, 11:22
by lumenvindex
franluciani wrote: 03 Nov 2019, 07:21
There is no secret technique to do this. You can only use one set of images for each subsection ("tens", "ones").
Of course you can try to use tricky "ones" images, that will cover some part of the "tens" images, but the result will hardly make you happy.
Posted: 03 Nov 2019, 11:24
by Maikeldevil
In this tool i can also load GTR faces, to bad the view space stays stuck on the miband size so i can only see one half of the face. Could the preview be extended to 454 x 454 for the GTR? That would be so awesome..
Posted: 03 Nov 2019, 17:47
by lumenvindex
Maikeldevil wrote: 03 Nov 2019, 11:24
It can be done, technically... But I'm not sure all the features of Mi Band 4 will work in GTR the same way. Will WF Tool pack everything right? Don't know anything about GTR...
Posted: 03 Nov 2019, 19:45
by franluciani
lumenvindex wrote: 03 Nov 2019, 11:22
Thanks for your answer. But it is not possible with this tricky because i need a number 1 for the "tens" when the "ones" have the number 1. But when the "ones" have other number (2,3,4,...) i need other image with 1 for the "tens".
The hours would be something like this:
_1_0
__11
_1_2
_1_3
Please if anyone know some trick to asign hour by hour an image please inform me.
Posted: 03 Nov 2019, 22:30
by Maikeldevil
lumenvindex wrote: 03 Nov 2019, 17:47
It would be great! The GTR is basicly a larger miband (gonna upgrade from mi Band to GTR). I opened various json gtr files in your tool, but can only work with half of the screen. So if you can make the window to 454px x 454px it would be awesome! Calibrating the X and Y can be so anoying sometimes!
Posted: 16 Nov 2019, 15:39
by alissonmoreira
Can anybody help me? I am trying to customize a theme that I downloaded here by applying seconds to it. Very useful for those who do physical exercises. However, when adding the option and selecting the existing png's, I put them in the desired position. When saving something happens in miband 4. When activating the miband I can see all information and then some disappear after 1sec. Appearing only if the miband is triggered. Previously the theme was statistical, I saw in this fórum that is a firmware bug. But I believe that was originated after applied modification by the tool
Posted: 16 Nov 2019, 19:10
by lumenvindex
alissonmoreira wrote: 16 Nov 2019, 15:39
It
is a firmware bug.
Digital seconds wipe everything but time. Analog seconds wipe only animation and pulse scale.
P.S. By the way, there is no stock watchfaces with seconds, at all. Why is that?
Posted: 20 Nov 2019, 06:22
by Benny_Emma
My virus scanner says it is a virus or malware into the EXE!
Posted: 20 Nov 2019, 10:23
by lumenvindex
You should read the original post.
Posted: 10 Dec 2019, 02:14
by amysanros
I can't generate my dial at all. The program always gives error when I save.
Posted: 10 Dec 2019, 05:06
by lumenvindex
amysanros wrote: 10 Dec 2019, 02:14
Trace|Loading resources for 4.4 'PulseWrapper'
Trace|Loading resources for 4.4.1 'Number'
Trace|Loading resources for 4.4.1.5 'TextAlignment'
Trace|Loading image -1...
Trace|File C:\Users\jonad\Music\Harry potter\LUFALUFA\lufalufawf\00-1.png doesn't exists.
Trace|File C:\Users\jonad\Music\Harry potter\LUFALUFA\lufalufawf\0-1.png doesn't exists.
Trace|File C:\Users\jonad\Music\Harry potter\LUFALUFA\lufalufawf\-1.png doesn't exists.
Fatal|System.IO.FileNotFoundException: File referenced by index -1 not found.
Looks like you've enabled
Activity-Pulse section but haven't chosen any images for it. Disable this section and try to pack again.
Posted: 17 Dec 2019, 22:12
by Batmat86
Thank you for the work, very practical and well done;)
Just a small improvement, I have the following error which I have to manually correct in the .json every time I want to make the .bin.
Fatal|[ERROR]Could not find member 'SuffixImageIndex' on object of type 'FormattedNumber'. Path 'Activity.Distance.SuffixImageIndex', line 69, position 25.
I remplaced it :
If an update could resolve this;)
And look forward to the weather being manageable on the mi band 4 in order to add the weather and the temperature on my skin.
Thanks again
P.S : Sorry for my English, i am French ...
Posted: 18 Dec 2019, 02:02
by lumenvindex
Batmat86 wrote: 17 Dec 2019, 22:12
You should just use one of the "Pack ..." buttons to make the bin.
It's a firmware issue. Current Mi Band firmwares simply do not give such info to the watchface.
Posted: 01 Jan 2020, 11:36
by Caz
Hi i love your WFbuilder i have made 4 great watch faces with it but now for some reason it says packing failed when i try to mke the bin file and its not making a bin file. I downloaded it again but it stll says the same thing, it wont even work on the watch faces i all ready made and i know they work ok as i made them and they work great on my Miband 4 watch.
can you help please as i loved being able to make my own watch faces
caz
Posted: 01 Jan 2020, 19:50
by lumenvindex
Caz wrote: 01 Jan 2020, 11:36
WF_Builder uses Mi Band 4 WF Tool for packing/unpacking watchfaces. If the packing procedure fails to complete, read the Tool's log file in the watchface directory to figure out what is the problem.
Posted: 02 Jan 2020, 14:19
by Caz
Hi I ran the file and got
Fatal |[ERROR] Watchface is greater than 321kb, it will not be accepted by Mi Band 4, please reduce size! Current size:903kb.
Fatal|System.ArgumentException: [ERROR] Watchface is greater than 321kb, it will not be accepted by Mi Band 4, please reduce size! Current size:903kb.
at WatchFace.Program.PackWatchFace(String inputFileName)
at WatchFace.Program.Main(String[] args)
but i dont understand why it says the file is great than 321kb, the file i unpacked was 229kb and i didnt touch anything just tried to pack it again
thanks for you help
caz
Posted: 02 Jan 2020, 16:02
by lumenvindex
Caz wrote: 02 Jan 2020, 14:19
There are three packing options in WF_Builder. You're probably using "as is" button. Try pushing
Pack (palette) or
Pack (choice) button (use F9 hotkey to switch between them). Also read the
Help about these options.
Posted: 02 Jan 2020, 19:53
by Caz
great, its working thank you
i was using "as is"
Pack (palette) works
and
save as works
thanks again for you help, while i am on is there an option to do miles instead of kilometers thanks
caz
Posted: 02 Jan 2020, 20:11
by lumenvindex
Caz wrote: 02 Jan 2020, 19:53
No, I still haven't update WF_Builder to use the latest Tool which has this feature.
Posted: 03 Jan 2020, 11:41
by Caz
ok, thanks
looking forward to when you up date WF_Builder
many thanks for a great app
caz
Posted: 14 Jan 2020, 20:34
by Caz
Hi
i love WF_Builder, its so great to use and i can make fantastic watch faces
is there any chance you could update WF_Builder to use the latest Tool so i could add miles, i would love to be able to add miles
thanks
caz
Posted: 15 Jan 2020, 05:19
by lumenvindex
Caz wrote: 14 Jan 2020, 20:34
Sorry, I'm too lazy for it.
But you can still get miles by editing a watchface manually. Just unpack you kms-watchface with the latest Tool, open json with notepad, find a string with "KmSuffixImageIndex" and replace this word with "MilesSuffixImageIndex". Then pack it with the latest Tool and you should get your miles-watchface.
Posted: 15 Jan 2020, 14:47
by Caz
Hi
thanks for you help. i tried thats but i seem to be doing something wrong< when i open the json there isnt a "KmSuffixImageIndex"
"Background": {
"Image": {
"X": 0,
"Y": 0,
"ImageIndex": 0
"Time": {
"Hours": {
"Tens": {
"X": 8,
"Y": 20,
"ImageIndex": 1,
"ImagesCount": 10
"Ones": {
"X": 31,
"Y": 20,
"ImageIndex": 1,
"ImagesCount": 10
"Minutes": {
"Tens": {
"X": 65,
"Y": 20,
"ImageIndex": 1,
"ImagesCount": 10
"Ones": {
"X": 91,
"Y": 20,
"ImageIndex": 1,
"ImagesCount": 10
"Activity": {
"Steps": {
"Number": {
"TopLeftX": -23,
"TopLeftY": 219,
"BottomRightX": 80,
"BottomRightY": 225,
"Alignment": "Center",
"Spacing": 2,
"ImageIndex": 11,
"ImagesCount": 10
"Pulse": {
"Number": {
"TopLeftX": 97,
"TopLeftY": 219,
"BottomRightX": -1,
"BottomRightY": 0,
"Alignment": "TopLeft",
"Spacing": 0,
"ImageIndex": 21,
"ImagesCount": 10
"NoDataImageIndex": 21
"Distance": {
"Number": {
"TopLeftX": 45,
"TopLeftY": 200,
"BottomRightX": 0,
"BottomRightY": 0,
"Spacing": 0,
"ImageIndex": 31,
"ImagesCount": 10
"SuffixImageIndex": 31,
"DecimalPointImageIndex": 121
"Date": {
"MonthAndDay": {
"Separate": {
"Month": {
"TopLeftX": 86,
"TopLeftY": 82,
"BottomRightX": 64,
"BottomRightY": 70,
"Alignment": "TopRight",
"Spacing": 1,
"ImageIndex": 41,
"ImagesCount": 10
"Day": {
"TopLeftX": 52,
"TopLeftY": 82,
"BottomRightX": 96,
"BottomRightY": 70,
"Spacing": 1,
"ImageIndex": 41,
"ImagesCount": 10
"TwoDigitsMonth": true,
"TwoDigitsDay": true
"WeekDay": {
"X": 17,
"Y": 83,
"ImageIndex": 100,
"ImagesCount": 21
"DayAMPM": {
"X": 120,
"Y": 250,
"ImageIndexAMCN": 122,
"ImageIndexPMCN": 123,
"ImageIndexAMEN": 124,
"ImageIndexPMEN": 125
"StepsProgress": {
"Linear": {
"StartImageIndex": 51,
"Segments": [
"X": 0,
"Y": 235
"X": 10,
"Y": 235
"X": 20,
"Y": 235
"X": 30,
"Y": 235
"X": 40,
"Y": 235
"X": 50,
"Y": 235
"X": 60,
"Y": 235
"X": 70,
"Y": 235
"X": 80,
"Y": 235
"X": 90,
"Y": 235
"X": 100,
"Y": 235
"X": 110,
"Y": 235
"Status": {
"DoNotDisturb": {
"Coordinates": {
"X": 4,
"Y": 5,
"BoxWidth": 17,
"Alignment": "Left",
"Order": 1
"ImageIndexOn": 126
"Lock": {
"Coordinates": {
"X": 21,
"Y": 5,
"BoxWidth": 17,
"Order": 1
"ImageIndexOn": 127
"Bluetooth": {
"Coordinates": {
"X": 38,
"Y": 5,
"BoxWidth": 12,
"Order": 1
"ImageIndexOff": 128
"Battery": {
"BatteryConfig": {
"BoxWidth": 0,
"Alignment": 0,
"Order": 0
"Text": {
"TopLeftX": 64,
"TopLeftY": 6,
"BottomRightX": 84,
"BottomRightY": 16,
"Spacing": 1,
"ImageIndex": 63,
"ImagesCount": 10
"Icon": {
"X": 98,
"Y": 5,
"ImageIndex": 73,
"ImagesCount": 9
"Other": {
"Animation": {
"AnimationImage": {
"X": -1,
"Y": 110,
"ImageIndex": 82,
"ImagesCount": 18,
"x3": 100
"Speed": 6,
"RepeatCount": 10,
"x2": 200
any idea what i have done wrong?
thanks again
caz
