lumenvindex
Been thanked: 49 times
Post by lumenvindex »
Download WF_Builder 1.0.4
Changelog
1.0.3
1.0.2
1.0.1
1.0.0
0.9.8
Fixed some bugs
0.9.7
0.9.6
Previous versions
1.0.3
Recommendations
Virus?
MESS WITH THE BEST
DIE LIKE THE REST
lumenvindex
Added WF_Builder 1.0.4 download link to the original post. Hope it will make your work more comfortable.
MESS WITH THE BEST
DIE LIKE THE REST
franluciani
Has thanked: 9 times
Been thanked: 6 times
Post by franluciani »
Hi, anyone know how to assign hour by hour an image? I say:
When "ten" value 1 and "ones" value 1, take this image for "ten".
But when "ten" value 1 and "ones" value 2, take this other image for "ten".
It is to put the number more to left or right when the number 1 is in the clock.
I'm creating the faces of apple watch and the only thing that left is it. Please if anyone know tell me.
lumenvindex
franluciani wrote: 03 Nov 2019, 07:21
There is no secret technique to do this. You can only use one set of images for each subsection ("tens", "ones").
Of course you can try to use tricky "ones" images, that will cover some part of the "tens" images, but the result will hardly make you happy.
MESS WITH THE BEST
DIE LIKE THE REST
Maikeldevil
Been thanked: 44 times
Post by Maikeldevil »
In this tool i can also load GTR faces, to bad the view space stays stuck on the miband size so i can only see one half of the face. Could the preview be extended to 454 x 454 for the GTR? That would be so awesome..
lumenvindex
Maikeldevil wrote: 03 Nov 2019, 11:24
It can be done, technically... But I'm not sure all the features of Mi Band 4 will work in GTR the same way. Will WF Tool pack everything right? Don't know anything about GTR...
MESS WITH THE BEST
DIE LIKE THE REST
franluciani
lumenvindex wrote: 03 Nov 2019, 11:22
Thanks for your answer. But it is not possible with this tricky because i need a number 1 for the "tens" when the "ones" have the number 1. But when the "ones" have other number (2,3,4,...) i need other image with 1 for the "tens".
The hours would be something like this:
_1_0
__11
_1_2
_1_3
Please if anyone know some trick to asign hour by hour an image please inform me.
Maikeldevil
lumenvindex wrote: 03 Nov 2019, 17:47
It would be great! The GTR is basicly a larger miband (gonna upgrade from mi Band to GTR). I opened various json gtr files in your tool, but can only work with half of the screen. So if you can make the window to 454px x 454px it would be awesome! Calibrating the X and Y can be so anoying sometimes!
alissonmoreira
Post by alissonmoreira »
Can anybody help me? I am trying to customize a theme that I downloaded here by applying seconds to it. Very useful for those who do physical exercises. However, when adding the option and selecting the existing png's, I put them in the desired position. When saving something happens in miband 4. When activating the miband I can see all information and then some disappear after 1sec. Appearing only if the miband is triggered. Previously the theme was statistical, I saw in this fórum that is a firmware bug. But I believe that was originated after applied modification by the tool :?: :cry:
lumenvindex
alissonmoreira wrote: 16 Nov 2019, 15:39
It is a firmware bug.
Digital seconds wipe everything but time. Analog seconds wipe only animation and pulse scale.
P.S. By the way, there is no stock watchfaces with seconds, at all. Why is that?
MESS WITH THE BEST
DIE LIKE THE REST
Benny_Emma
Post by Benny_Emma »
My virus scanner says it is a virus or malware into the EXE!
lumenvindex
Benny_Emma wrote: 20 Nov 2019, 06:22
it is a virus
You should read the original post.
MESS WITH THE BEST
DIE LIKE THE REST
amysanros
Post by amysanros »
I can't generate my dial at all. The program always gives error when I save.
lufalufawf_packed.log
(29.61 KiB) Downloaded 219 times
lumenvindex
amysanros wrote: 10 Dec 2019, 02:14
Trace|Loading resources for 4.4 'PulseWrapper'
Trace|Loading resources for 4.4.1 'Number'
Trace|Loading resources for 4.4.1.5 'TextAlignment'
Trace|Loading image -1...
Trace|File C:\Users\jonad\Music\Harry potter\LUFALUFA\lufalufawf\00-1.png doesn't exists.
Trace|File C:\Users\jonad\Music\Harry potter\LUFALUFA\lufalufawf\0-1.png doesn't exists.
Trace|File C:\Users\jonad\Music\Harry potter\LUFALUFA\lufalufawf\-1.png doesn't exists.
Fatal|System.IO.FileNotFoundException: File referenced by index -1 not found.
Looks like you've enabled Activity-Pulse section but haven't chosen any images for it. Disable this section and try to pack again.
MESS WITH THE BEST
DIE LIKE THE REST
Batmat86
Post by Batmat86 »
Thank you for the work, very practical and well done;)
Just a small improvement, I have the following error which I have to manually correct in the .json every time I want to make the .bin.
Fatal|[ERROR]Could not find member 'SuffixImageIndex' on object of type 'FormattedNumber'. Path 'Activity.Distance.SuffixImageIndex', line 69, position 25.
I remplaced it :
"KMSuffixImageIndex":
If an update could resolve this;)
And look forward to the weather being manageable on the mi band 4 in order to add the weather and the temperature on my skin.
Thanks again
P.S : Sorry for my English, i am French ...
lumenvindex
Batmat86 wrote: 17 Dec 2019, 22:12
You should just use one of the "Pack ..." buttons to make the bin.
It's a firmware issue. Current Mi Band firmwares simply do not give such info to the watchface.
MESS WITH THE BEST
DIE LIKE THE REST
Caz
Post by Caz »
Hi i love your WFbuilder i have made 4 great watch faces with it but now for some reason it says packing failed when i try to mke the bin file and its not making a bin file. I downloaded it again but it stll says the same thing, it wont even work on the watch faces i all ready made and i know they work ok as i made them and they work great on my Miband 4 watch.
can you help please as i loved being able to make my own watch faces
caz
lumenvindex
Caz wrote: 01 Jan 2020, 11:36
WF_Builder uses Mi Band 4 WF Tool for packing/unpacking watchfaces. If the packing procedure fails to complete, read the Tool's log file in the watchface directory to figure out what is the problem.
MESS WITH THE BEST
DIE LIKE THE REST
Caz
Post by Caz »
Hi I ran the file and got
Fatal |[ERROR] Watchface is greater than 321kb, it will not be accepted by Mi Band 4, please reduce size! Current size:903kb.
Fatal|System.ArgumentException: [ERROR] Watchface is greater than 321kb, it will not be accepted by Mi Band 4, please reduce size! Current size:903kb.
at WatchFace.Program.PackWatchFace(String inputFileName)
at WatchFace.Program.Main(String[] args)
but i dont understand why it says the file is great than 321kb, the file i unpacked was 229kb and i didnt touch anything just tried to pack it again
thanks for you help
caz
lumenvindex
Caz wrote: 02 Jan 2020, 14:19
There are three packing options in WF_Builder. You're probably using "as is" button. Try pushing Pack (palette) or Pack (choice) button (use F9 hotkey to switch between them). Also read the Help about these options.
MESS WITH THE BEST
DIE LIKE THE REST
Caz
Post by Caz »
great, its working thank you
i was using "as is"
Pack (palette) works
and
save as works
thanks again for you help, while i am on is there an option to do miles instead of kilometers thanks
caz
lumenvindex
Caz wrote: 02 Jan 2020, 19:53
No, I still haven't update WF_Builder to use the latest Tool which has this feature.
MESS WITH THE BEST
DIE LIKE THE REST
Caz
Post by Caz »
ok, thanks
looking forward to when you up date WF_Builder
many thanks for a great app
caz
Caz
Post by Caz »
Hi
i love WF_Builder, its so great to use and i can make fantastic watch faces
is there any chance you could update WF_Builder to use the latest Tool so i could add miles, i would love to be able to add miles
thanks
caz
lumenvindex
Caz wrote: 14 Jan 2020, 20:34
Sorry, I'm too lazy for it.
But you can still get miles by editing a watchface manually. Just unpack you kms-watchface with the latest Tool, open json with notepad, find a string with "KmSuffixImageIndex" and replace this word with "MilesSuffixImageIndex". Then pack it with the latest Tool and you should get your miles-watchface. :D
MESS WITH THE BEST
DIE LIKE THE REST
Caz
Post by Caz »
Hi
thanks for you help. i tried thats but i seem to be doing something wrong< when i open the json there isnt a "KmSuffixImageIndex"
"Background": {
"Image": {
"X": 0,
"Y": 0,
"ImageIndex": 0
"Time": {
"Hours": {
"Tens": {
"X": 8,
"Y": 20,
"ImageIndex": 1,
"ImagesCount": 10
"Ones": {
"X": 31,
"Y": 20,
"ImageIndex": 1,
"ImagesCount": 10
"Minutes": {
"Tens": {
"X": 65,
"Y": 20,
"ImageIndex": 1,
"ImagesCount": 10
"Ones": {
"X": 91,
"Y": 20,
"ImageIndex": 1,
"ImagesCount": 10
"Activity": {
"Steps": {
"Number": {
"TopLeftX": -23,
"TopLeftY": 219,
"BottomRightX": 80,
"BottomRightY": 225,
"Alignment": "Center",
"Spacing": 2,
"ImageIndex": 11,
"ImagesCount": 10
"Pulse": {
"Number": {
"TopLeftX": 97,
"TopLeftY": 219,
"BottomRightX": -1,
"BottomRightY": 0,
"Alignment": "TopLeft",
"Spacing": 0,
"ImageIndex": 21,
"ImagesCount": 10
"NoDataImageIndex": 21
"Distance": {
"Number": {
"TopLeftX": 45,
"TopLeftY": 200,
"BottomRightX": 0,
"BottomRightY": 0,
"Spacing": 0,
"ImageIndex": 31,
"ImagesCount": 10
"SuffixImageIndex": 31,
"DecimalPointImageIndex": 121
"Date": {
"MonthAndDay": {
"Separate": {
"Month": {
"TopLeftX": 86,
"TopLeftY": 82,
"BottomRightX": 64,
"BottomRightY": 70,
"Alignment": "TopRight",
"Spacing": 1,
"ImageIndex": 41,
"ImagesCount": 10
"Day": {
"TopLeftX": 52,
"TopLeftY": 82,
"BottomRightX": 96,
"BottomRightY": 70,
"Spacing": 1,
"ImageIndex": 41,
"ImagesCount": 10
"TwoDigitsMonth": true,
"TwoDigitsDay": true
"WeekDay": {
"X": 17,
"Y": 83,
"ImageIndex": 100,
"ImagesCount": 21
"DayAMPM": {
"X": 120,
"Y": 250,
"ImageIndexAMCN": 122,
"ImageIndexPMCN": 123,
"ImageIndexAMEN": 124,
"ImageIndexPMEN": 125
"StepsProgress": {
"Linear": {
"StartImageIndex": 51,
"Segments": [
"X": 0,
"Y": 235
"X": 10,
"Y": 235
"X": 20,
"Y": 235
"X": 30,
"Y": 235
"X": 40,
"Y": 235
"X": 50,
"Y": 235
"X": 60,
"Y": 235
"X": 70,
"Y": 235
"X": 80,
"Y": 235
"X": 90,
"Y": 235
"X": 100,
"Y": 235
"X": 110,
"Y": 235
"Status": {
"DoNotDisturb": {
"Coordinates": {
"X": 4,
"Y": 5,
"BoxWidth": 17,
"Alignment": "Left",
"Order": 1
"ImageIndexOn": 126
"Lock": {
"Coordinates": {
"X": 21,
"Y": 5,
"BoxWidth": 17,
"Order": 1
"ImageIndexOn": 127
"Bluetooth": {
"Coordinates": {
"X": 38,
"Y": 5,
"BoxWidth": 12,
"Order": 1
"ImageIndexOff": 128
"Battery": {
"BatteryConfig": {
"BoxWidth": 0,
"Alignment": 0,
"Order": 0
"Text": {
"TopLeftX": 64,
"TopLeftY": 6,
"BottomRightX": 84,
"BottomRightY": 16,
"Spacing": 1,
"ImageIndex": 63,
"ImagesCount": 10
"Icon": {
"X": 98,
"Y": 5,
"ImageIndex": 73,
"ImagesCount": 9
"Other": {
"Animation": {
"AnimationImage": {
"X": -1,
"Y": 110,
"ImageIndex": 82,
"ImagesCount": 18,
"x3": 100
"Speed": 6,
"RepeatCount": 10,
"x2": 200
any idea what i have done wrong?
thanks again
caz
