lumenvindex
Been thanked: 49 times
Post by lumenvindex »
Download WF_Builder 1.0.4
Changelog
1.0.3
1.0.2
1.0.1
1.0.0
0.9.8
Fixed some bugs
0.9.7
0.9.6
Previous versions
1.0.3
Recommendations
Virus?
MESS WITH THE BEST
DIE LIKE THE REST
lumenvindex
Notarino wrote: 15 Oct 2019, 10:03
Could anyone make the watchface ???
You should ask about it here.
If you have some problems with WF_Builder, be more specific.
MESS WITH THE BEST
DIE LIKE THE REST
phamaral
Post by phamaral »
You can only use transparency of the image to show what's under the battery icon.
Thanks for the tip! That probably will work in my case. Only problem I'm facing now is getting a usable file size using the "as is" packing method since pallete won't allow partially opaque images. Any ideas?
lumenvindex
phamaral wrote: 15 Oct 2019, 12:25
Palette mode doesn't allow to use partly-transparent colors in the image, it turns such pixels into fully opaque or fully transparent.
But if you need to have partly-transparent colors in SOME (not all) of the images, you can enable "Selective palette mode" feature in Options dialog and select some images to be left "as is" during the packing procedure.
MESS WITH THE BEST
DIE LIKE THE REST
technofab
Post by technofab »
Very useful tool. A request if actual is not possibile: how I can select month day in the format DD MM or MM DD ? for now I see only MM DD! Thanks in advance.
lumenvindex
technofab wrote: 15 Oct 2019, 14:51
You can't change the format for One line date, but you can use Separate - Day and Separate - Month placing them nearby. The separator can be drawn on a background image if needed.
MESS WITH THE BEST
DIE LIKE THE REST
technofab
Post by technofab »
lumenvindex wrote: 15 Oct 2019, 15:15
yes, I'm testing that, but I need to remodify the background image. It wasl helpful if the oneline date can be selectable in both modes or the separate day - month can have a seperator image to select.
lumenvindex
technofab wrote: 15 Oct 2019, 15:19
Sadly, the Mi Band firmware doesn't allow that.
MESS WITH THE BEST
DIE LIKE THE REST
tigre652
Post by tigre652 »
I have cteate my first watchfacr with etitor
I have push save as and create a folder with a png file... and now?
How create a bin file?
lumenvindex
tigre652 wrote: 16 Oct 2019, 18:14
To create a bin file you need to Pack the watchface in palette or raw ("as is") mode. Read Help to know the difference between them.
MESS WITH THE BEST
DIE LIKE THE REST
tigre652
Post by tigre652 »
Message error pack palette is failed!
tigre652
Post by tigre652 »
Packing failed
lumenvindex
tigre652 wrote: 17 Oct 2019, 08:51
Packing failed
WF_Builder uses Mi Band 4 WF Tool for packing. Check it's log file in the json directory.
MESS WITH THE BEST
DIE LIKE THE REST
lumenvindex
WF_Builder 1.0.3 is uploaded. Check the original post.
MESS WITH THE BEST
DIE LIKE THE REST
tigre652
Post by tigre652 »
Ok i complete my work:
https://amazfitwatchfaces.com/mi-band-4/view/8211
1 Two problem, I cannot align the numbers of steps and pulses on the right as you can see from the preview.
2 Is it possible to enter the outside temperature?
tigre652
Post by tigre652 »
tigre652 wrote: 17 Oct 2019, 13:08
1 3 problem, I cannot align the numbers of steps and pulses on the right as you can see from the preview.
3 why the date and date on the pulse and steps disappear after 1sec?
lumenvindex
1. Horizontal alignment works only when ALL the numbers+spacings fit into the box from X1:Y1 to X2:Y2 horizontally.
Vertical alignment works only on images which fit into the box from X1:Y1 to X2:Y2 vertically.
2. No, current firmware doesn't support this.
3. Current firmware(s) bug.
MESS WITH THE BEST
DIE LIKE THE REST
tigre652
Post by tigre652 »
3 is problem firmware miband4, not software tools?
Thanks for your work.
lumenvindex
tigre652 wrote: 17 Oct 2019, 13:35
Yes, it's a bug of Mi Band firmware.
MESS WITH THE BEST
DIE LIKE THE REST
technofab
Post by technofab »
lumenvindex wrote: 15 Oct 2019, 16:25
Ouch, very sad. Thanks for the explanation. :)
TaylanTatli
Post by TaylanTatli »
Can you make a linux version? Trying to run with wine but it seems broken;
imggmi .com/full/2019/10/19/853398f0b414333a42e0163a6b08314c-full.png.html (remove the space site doesn't allow me to share image)
lumenvindex
TaylanTatli wrote: 19 Oct 2019, 15:57
The only way to make a linux version is to write the program from scratch using some other than Autoit language. I'm not planning to do it.
MESS WITH THE BEST
DIE LIKE THE REST
technofab
Post by technofab »
lumenvindex wrote: 19 Oct 2019, 16:05
Wow is made with AutoIt? Many many compliments. I use that at my job!!!
I want also to thank you, I made my first personal face, and publish here.
Fiorentina Fans had finally a watchface! :D
Nomek
Post by Nomek »
Just one question. Is there a detailed command list for the *.json file?
I'm trying to find out if there is a command "Year" to add the current year in Mi Band 4 watchface.
Any kind of help is wellcome.
jellynettle
Post by jellynettle »
I don't think there is but you can easily just put 2019 in the background, updating it manually if you'll still like said watchface
lumenvindex
Nomek wrote: 24 Oct 2019, 14:26
WF_Builder uses all known json parameters. You can find the list of them in this file:
right_order.zip
(1.34 KiB) Downloaded 284 times
There is no Year section or value.
MESS WITH THE BEST
DIE LIKE THE REST
