AmazFaces APP (Android) open BETA
berilopassos
Post by berilopassos »
Dears, after installing the update for the AmazFaces beta App released yesterday, everything is working correctly. Developers, thank you very much for your support.
osmat
Admin
Has thanked: 35 times
Been thanked: 73 times
Post by osmat »
berilopassos wrote: 18 Feb 2020, 14:02
Without your feedback, we would not have done it! Thank you for trusting us.
jmpnm
Post by jmpnm »
Hi!, thanks for your work...
Can not download any watchface to GTS or T-Rex, when I press substitute to a local skin it does not do anything...First I had download a local stock skin to any of the smartwatches witout any problem and I gave AmazFaces app permissions to files.
Sorry for my English, as it is not my native language.
osmat
Admin
Post by osmat »
jmpnm wrote: 20 Feb 2020, 08:59
A small guide for interacting with watches through AmazFaces
1.Turn on discovery in Amazfit.
2.Wait for synchronization.
3.Open AmazFaces and try the installation.
4.If the clock is still not connected.
5.Open the bluetooth settings.
6.Remove the watch from the list of paired devices.
7.Start at point 1
Important AmazFaces application must receive all permissions, including access to geolocation.
jmpnm
Post by jmpnm »
osmat wrote: 20 Feb 2020, 21:19
7.Start at point 1
ThIs is a guide for Direct Instalation....does not work by that installation method, never connect to smartwatch. I was trying the other option on instalation method "Copy to watch_skin_local".
EDIT: Ok, I got it, with " Direct Instalation" mode, on amazfaces app after pressing download I need to " start discovery" and then smartwatch is found and download firmare starts
osmat
Admin
Post by osmat »
jmpnm wrote: 21 Feb 2020, 13:23
7.Start at point 1
In the example, I described one of the installation methods. The easiest in my opinion and 100% working
Arz
Post by Arz »
Guys how do i download and install a face using this app please
osmat
Admin
Post by osmat »
Arz wrote: 27 Feb 2020, 14:09
What is your watch?
ravirajadke
Post by ravirajadke »
android is wast syllabus wgich is give you better carrier
Najimi
Post by Najimi »
not working for amazfit pace
osmat
Admin
Post by osmat »
Najimi wrote: 08 Mar 2020, 14:32
Describe what you are doing and what mistakes you have, we will help you.
Xouzouris
Post by Xouzouris »
Hi, it's not working with my Stratos either (direct installation, no app on the watch). I can't find this discovery mode you're talking about on the app. However, the watch is connected to the phone and synced. Then, when I try to install a watchface, it hangs for a while "initializing" and then fails. What am I doing wrong?
osmat
Admin
Post by osmat »
Xouzouris wrote: 10 Mar 2020, 15:31
There is another way for stratos. With direct installation, the application runs on the wi fi watch. The phone should connect to this network and open Amazfit, after which the installation should go. Or you need to install the Amazfit service on your watch. https://amazfitwatchfaces.com/awapp
Or if you use Amazmod, you can install through it, just click share and select amazmod
LukasMoraes
Post by LukasMoraes »
[mention]osmat[/mention]
hi. i don't understand your answer. Do you can help me please? i have the same problem.
My phone and the watch are in the same wifi network, but they not sinc the AW app.
The message is "Somthing wrong wait 3-5 sec and retry install"
I'm using Stratos + Mi 9T PRO, both are updated to last version firmware.
Tks
___________________
LukasMoraes
LukasMoraes
osmat wrote: 10 Mar 2020, 22:52
Tks
____________
LukasMoraes
osmat
Admin
Post by osmat »
Next to the download button there is a gear click it there is a choice of two installation methods
Najimi
Post by Najimi »
ok thank you
I had already app amazfit faces on my phone but how can i conncted my watch with it. i have amazfit pace watch
and how can i transfer the faces from the app into my watch
osmat
Admin
Post by osmat »
Najimi wrote: 11 Mar 2020, 20:32
ok thank you
davidbennelf29
Post by davidbennelf29 »
Não está sincronizando com o gtr , está dando erro e não consigo usar mais nenhuma whatface do app
osmat
Admin
Post by osmat »
davidbennelf29 wrote: 28 Mar 2020, 11:28
This happened after the last update ?
Eurico Lucas
Post by Eurico Lucas »
Meu gt-r tbm não esta conseguindo trocar a face, toda vez q carrega 100% aparece erro de sincronização
osmat
Admin
Post by osmat »
Eurico Lucas wrote: 03 Jun 2020, 19:39
Envie um screenshot.
Adore_able
Been thanked: 6 times
Post by Adore_able »
Thanks the app works perfectly on Android
Awesome!
Cheers!!!!
Inspiring great affection and delight
GloriousMorningstar
Post by GloriousMorningstar »
It works to set a watch face in smart mode, but when I switch to ultra mode it changes back to a basic watch face.
Has thanked: 1105 times
Been thanked: 266 times
GloriousMorningstar wrote: 30 Aug 2020, 12:14
It's normal.
Return to “AmazFaces app”
