spidercrab 写了: 19 6月 2021, 11:19
I found a solution to uploading a WF from the Amazface iOS App losing the bluetooth connection or failing and showing the "Make sure Zepp is Running" fail message.
I restored my TRexPro to factory Settings, and the zepp App restored everything, which is good to know.
However, I was still getting connection problems. The solution, was to make sure that the watch is being charged when uploading. This worked for me on an iPhone6S with iOS 14.6.
Update: I did charge the phone when installing, but first I deleted one of my old watchfaces and magically it worked.
So, bottom line is: keep the watch charging, delete one of your old watch faces, amaz watch faces, choose the one you like, share it to amaztools, you get an error code, click on the 3 dots on the top right, select custom file type, watchfaces and then install - it WILL work then. Phew!!!!
