AmazFaces for iOS [Support]
Has thanked: 1162 times
Been thanked: 278 times
In this topic, you may report a problem with our AmazFaces app for iOS.
App version (Stable or Beta)
Watch model
Phone model
OS version
Description of your problem
Filling example:
App version: 3.0.111 Stable
Watch model: GTR
Phone model: iPhone 11
OS version: iOS 14.2
spidercrab
Has thanked: 27 times
Post by spidercrab »
App version :3.4.112
Amaztools 1.27
watch model : TRexPro
Phone model : iPhone 6s
OS version : ios 14.5.1
I can finally upload WFs to my iPhone. Still no luck with the WF App but I can upload using Amaztools. AT fails on the first attempt but restarting Amaztools and trying again works.
CSAleck1808
Post by CSAleck1808 »
I changed a T-REX to a T-REX PRO and I can't change the face of the watch. I've checked everything in terms of connection and nothing advances. Before, it worked perfectly with the T-REX.
ZEPP APP
watch model : TRex Pro
FIRMWARE: 2.0.1.02
Phone model : iPhone 8 PLUS
ronakjbhagat
Post by ronakjbhagat »
Hey, am having same problem on Amazfit GTS 2 Mini
Stas
Been thanked: 34 times
Post by Stas »
Check the new version 3.5, if the error persists, then write about the problem
ronakjbhagat wrote: 25 May 2021, 13:35
scandistars
Post by scandistars »
In the app for iPhone there are now two options for installing watchfaces; Low or Fast. What is the difference?
I can understand if it was "slow" or "fast", but "LOW" and "FAST" have no relation so I don't understand which option to use when installing. Thanks otherwise for a great app!!
Stas
Post by Stas »
The difference in packet size when transferring a file, for some device models do not support large packages, this is a temporary function.
scandistars wrote: 06 Jun 2021, 00:51
Stas
Post by Stas »
Check out the device discovery mode enabled, sometimes when battery low automatically shuts off Discovery mode
Cutandpaste wrote: 08 Jun 2021, 00:25
App version - 3.5 (stable)
Watch: Amazfit GTR 47mm
Phone: iPhone SE 2020
OS version: iOS 14.6
Zepp: synced with watch. All functions working, Watch discoverable etc.
Amazfaces app: Watch face downloaded. DEVICE DISCOVERY REPEATEDLY FAILS. Error message asks me to do thing I already have done, like keeping Zepp running in background etc.
spidercrab
I have been unable to upload wf's to my TRexPro, using the AmazFaces App, since around the time of the last iOS update to 14.6 recently. The app identifies the watch ok but briefly displays a message saying there isn’t enough space on the watch. However, that message quickly dissappears and it looks like the transfer is starting. However, I then get the dreaded make sure Zepp is running, which it is.
I only have the min 3 default wfs and one 320kb wf on the watch.
FWIW, Amaztools also cant upload wf's.
App version: 3.5.116 Stable
Watch model: TRexPro
Phone model: iPhone 6S
Latest Zepp
Also, I couldn't report this using the App report feature, because the Send button is hidden by some text under the Enter Text area. I can enter my message but there is novisible Send button.
joujc5913
Post by joujc5913 »
請教在AmazFaces上下載 GTS2 mini的錶盤,都無法直接連結到GTS2 mini設備來安裝任何錶盤。總是彈出到 zepp 應用程式窗口,請教如何解決,是我操作上的問題嗎?感謝請解惑.
jdmf13
Post by jdmf13 »
I'm unable to login with my AmazfitWatchFaces account on the AmazFaces iOS App.
I fill in my details and click "Sign In" and then it will stay with "Please Wait" and never advances.
spidercrab
I found a solution to uploading a WF from the Amazface iOS App losing the bluetooth connection or failing and showing the "Make sure Zepp is Running" fail message.
I restored my TRexPro to factory Settings, and the zepp App restored everything, which is good to know.
However, I was still getting connection problems. The solution, was to make sure that the watch is being charged when uploading. This worked for me on an iPhone6S with iOS 14.6.
Jchang0125
Post by Jchang0125 »
應用版本: 3.5.116
手錶型號:
T-REX
手機型號: iPhone 8+
11 專業操作系統版本 : iOS 14.6 AmazFaces無法連線設備 ,但Zepp可以連線也可以更換Zepp上的錶盤
AmazFaces cannot connect to the device, but Zepp can connect or change the dial on Zepp
Stas
Post by Stas »
Within a week there will be an update with fixes
Jchang0125 wrote: 28 Jun 2021, 13:52
應用版本: 3.5.116
手錶型號:
T-REX
手機型號: iPhone 8+
Rodrigoanestesia
Post by Rodrigoanestesia »
spidercrab wrote: 19 Jun 2021, 11:19
I have tried this method today. I hot the watch charging, and it is still not working. The difference is, it now starts to download but in the end I get the infamous “generic error code”and it does not install. Frustrating at least.
Rodrigoanestesia
Update: I did charge the phone when installing, but first I deleted one of my old watchfaces and magically it worked.
So, bottom line is: keep the watch charging, delete one of your old watch faces, amaz watch faces, choose the one you like, share it to amaztools, you get an error code, click on the 3 dots on the top right, select custom file type, watchfaces and then install - it WILL work then. Phew!!!!
rafarezador
Post by rafarezador »
Watch model: Mi band 6
Phone model: iPhone 8 plus
OS version: iOS 14.7.1
Not able to sync
Stas
Post by Stas »
Hi, we know about the problem and will try to solve it as soon as possible.
rafarezador wrote: 12 Aug 2021, 15:20
Not able to sync
since0604
Post by since0604 »
I'm downloading my watchface from amazfitwatchfaces, and I'm still getting errors synchronizing with my watchface from my band6.
ios ver14.7
iphone se
mi band6
Stas
Post by Stas »
An update with fixes will be released soon, check in versions 117 and above
since0604 wrote: 16 Aug 2021, 11:34
ios ver14.7
iphone se
mi band6
since0604
Post by since0604 »
Stas wrote: 17 Aug 2021, 10:14
ios ver14.7
iphone se
mi band6
If you don't mind, can I know when 117 will be updated?
hexas
Post by hexas »
App version: 3.6.120
Watch model: T REX
OS version: iOS 14.71
Stas
Post by Stas »
We know about the problem with T-Rex update coming soon.
hexas wrote: 16 Sep 2021, 15:42
Watch model: T REX
jonathanff
Post by jonathanff »
Watch model: T REX
No meu celular não sincroniza o App.
Stas
Post by Stas »
We would be grateful if you check the beta version and write the test result.
link to beta test TestFlight:
https://testflight.apple.com/join/4hBEKHHg
jonathanff wrote: 18 Sep 2021, 12:41
Watch model: T REX
extremme
Post by extremme »
Watch model: T REX
Phone model: iPhone 11 Pro Max
OS version: iOS 14.8
I have a T-Rex. I was able to download and update my watch faces without issue. The last time I changed was abt 2 months ago.
I am using Iphone 11 pro max and 2 days ago, I updated the IOS to 14.8.
I tried updating the faces to my watch. It will indicate on my watch "Syncing Watch....." and on my phone it will show the progress. When it reached 100%, my watch will show error to upload face. I tried many times and tried to reinstall Amazfaces app but to no avail. (My Zepp app was still running at the background)
I then tried to use the Zepp app to try and see if I can change the face using their default watch faces and it worked. So it not bluetooth connection issue.
Return to “AmazFaces app”
