• Administrador
Verified authors ✅ (OLD)
Avatar de Usuario
Has thanked: 1162 times
Been thanked: 279 times
Contactar:
Mensaje por GIK-Team »
Our team decided to close the Verified Authors group due to the increase of controversial and negative situations and non-compliance with the rules by members of this group. From now on, we will stop accepting applications for membership. Though this is not the end, but the beginning of something new. Verified Authors group was created to protect and encourage original authors, but unfortunately, this idea stopped working. The rules and concepts of the group will be revised. Perhaps, some users will be excluded. We are now disabling the Verified Authors labels on all works, while the rules and benefits of the group continue to apply to all its members until we publish new information here.
old rules
  1. The works of such authors are marked with a special sticker (blue checkmark).
  2. Advertising is not displayed for this group of authors.
  3. An author may specify a link to PayPal or other ways to collect donations when uploading the work on the website.
  4. Copying or modifying works of verified authors on our resource is possible only by agreement with the author.
  5. In the case of unauthorized copying, the verified author has the right to file a complaint and the administration of the website will immediately remove modification or copy of his/her work.*
*Complaints are considered only within the catalog of this website. Watch faces published on other resources are not taken into account and cannot be regarded as the original (primary source). All complaints can be considered within the branch where the work is published. If someone adapts your work for other watches, then there is a standard rule for such an issue, which is: the author who adapted someone's work must indicate the original author (source) in the description.
This group was created to distinguish and protect those authors, who spend a lot of time and energy on the design and creation of their own watchfaces. This means that watchfaces should not repeat either the style, fonts, background, etc. of other works on the website. The administration of the website also do not accept authors who have many similar works (copies of one and the same watchface with slight differences).
  1. You need to have a minimum of 5 completely different works uploaded on our website (Published separately).**
  2. Your works have to be designed by you and popular on the site.***
  3. All posted works should have a completed description and correct tags.
  4. The author should respond to comments under his/her work.
**Watchfaces that are ported from other watches or copies of watchfaces from famous brands of watches or smartwatches will be not considered.
***Popularity is determined by visitors of the website, i.e. such indicators as views, downloads, favorites are taken into account when considering.
Applications are processed within 7-14 days and the author receives a response in any case (either positive or negative).
Notice: After joining the group, you must update your watchfaces to receive a sticker (just enter the editing mode and re-save your watchface)
Avatar de Usuario
osmat
Admin
Has thanked: 35 times
Been thanked: 73 times
Contactar:
Mensaje por osmat »
Warley escribió: 17 Feb 2021, 18:07
Hello! i´m Warley, a argentinian designer. I´ would like to apply to become a Verified Author. Thanks!
Thank you for contacting us, but we have to refuse you
Avatar de Usuario
Warley
Contactar:
Mensaje por Warley »
Hi Osmat, I can know the reason why I am refuse or what I have to change?
Avatar de Usuario
osmat
Admin
Contactar:
Mensaje por osmat »
Warley escribió: 17 Feb 2021, 21:31
Read the attached message!
All the criteria are listed there
Both objective and possibly subjective
We try to weigh the pros and cons when evaluating that would be a balance of opinions.
For this reason do not consider the same type of work as a separate.
Avatar de Usuario
Contactar:
You are a new user on the site. We cannot even estimate the popularity of your work. It takes more time. ;)
POWERLIFTER.RPL
Mensaje por POWERLIFTER.RPL »
как запустить процедуру проверенного автора?
Avatar de Usuario
osmat
Admin
Contactar:
Mensaje por osmat »
POWERLIFTER.RPL escribió: 19 Feb 2021, 18:13
Thank you for leaving a request. We have studied your work and are forced to refuse you due to non-compliance with the resource rules of some of your works. Note that the group membership requirements are aimed at encouraging authors to create unique watch faces. In turn, in the rules of the resource, we prohibit the use of the names of famous watch brands, their logos and designs. All such works are removed from the resource at the request of the owner's rights.
POWERLIFTER.RPL
но у меня так же имеются полностью мои работы, а не переделки известных брендов
josekso
Contactar:
Mensaje por josekso »
GIK-Team escribió: 09 Sep 2020, 16:58
josekso escribió: 09 Sep 2020, 12:53
Can I be a member of the group?
Done ✅
I am no longer a member, can I become a member again? Thanks!
Avatar de Usuario
Contactar:
josekso escribió: 23 Feb 2021, 12:13
Done ✅
Yes. But remember, If there is no activity for more than three weeks, the user can be excluded from the group without further notice.
POWERLIFTER.RPL
когда повторно можно подать заявку?
Avatar de Usuario
Contactar:
POWERLIFTER.RPL escribió: 24 Feb 2021, 06:41
У вас в профиле 0 циферблатов, а нужно минимум 5.
POWERLIFTER.RPL
GIK-Team escribió: 26 Feb 2021, 15:18
ваши кони тихо скачут, или собака след не берет. было более 50, все удалил. не считаю нужным более делиться у вас на форуме, смысла не вижу
Avatar de Usuario
Contactar:
POWERLIFTER.RPL escribió: 26 Feb 2021, 18:10
Всего хорошего.
IgorKH
Contactar:
Mensaje por IgorKH »
Здравствуйте! Можно вступить в группу?
Avatar de Usuario
splash
Contactar:
Mensaje por splash »
Hello. I want to get into the group verified authors. I have more than 5 unique multilingual WFS for GTS 2 mini. I also do ports and translations of other WFS. I want to continue creating WF as a verified author.
Avatar de Usuario
osmat
Admin
Contactar:
Mensaje por osmat »
IgorKH escribió: 08 Mar 2021, 03:24
Thank you for leaving a request. You have interesting work, but so far we have to refuse you. Keep doing amazing work and we will add you to the group.
Avatar de Usuario
osmat
Admin
Contactar:
Mensaje por osmat »
splash escribió: 09 Mar 2021, 07:55
Thank you for your request, it has been approved.
Avatar de Usuario
Contactar:
С момента вашей регистрации на сайте прошло слишком мало времени, подайте повторную заявку через пару недель. Спасибо.
Avatar de Usuario
Sim.md
Contactar:
Mensaje por Sim.md »
Добрый день, можно вступить в группу? мои циферблаты довольно популярны уже
Случайности не случайны
Avatar de Usuario
osmat
Admin
Contactar:
Mensaje por osmat »
Sim.md escribió: 12 Mar 2021, 16:44
Welcome to the group
valeri6524
Contactar:
Mensaje por valeri6524 »
Good afternoon, I want to apply to become a verified author, thanks for the help!
Добрейшего времени суток , можно меня добавить в группу?
Avatar de Usuario
Drongo
Watchmen
Has thanked: 34 times
Been thanked: 12 times
Contactar:
Mensaje por Drongo »
valeri6524 escribió: 13 Mar 2021, 13:32
Welcome to the group!
Bruno79
Contactar:
Mensaje por Bruno79 »
Welcome to the group! I upload first mode with MiBand5. I want to apply to become a verified author, thanks for the help!
Regards :)
Avatar de Usuario
Contactar:
Bruno79 escribió: 15 Mar 2021, 17:13
Regards :)
Read carefully the first post ;)
Inquisitom
Has thanked: 11 times
Been thanked: 14 times
Contactar:
Mensaje por Inquisitom »
I'd like to be part of verified authors if possible. As little background, I have reworked SashaCX75 tool to integrate more options for AmazfitX (link here), and also created several faces for this watch. I just do it for fun, and really enjoy this :)
May I ask you to consider SandraMichael work too, as I'm sure this WF creator should deserve the right to be a verified author.
Thanks in advance.
Cerrado
Volver a “Closed topics”
¿Quién está conectado?
