Verified authors ✅ (OLD)
Has thanked: 1149 times
Been thanked: 277 times
Our team decided to close the Verified Authors group due to the increase of controversial and negative situations and non-compliance with the rules by members of this group. From now on, we will stop accepting applications for membership. Though this is not the end, but the beginning of something new. Verified Authors group was created to protect and encourage original authors, but unfortunately, this idea stopped working. The rules and concepts of the group will be revised. Perhaps, some users will be excluded. We are now disabling the Verified Authors labels on all works, while the rules and benefits of the group continue to apply to all its members until we publish new information here.
old rules
  1. The works of such authors are marked with a special sticker (blue checkmark).
  2. Advertising is not displayed for this group of authors.
  3. An author may specify a link to PayPal or other ways to collect donations when uploading the work on the website.
  4. Copying or modifying works of verified authors on our resource is possible only by agreement with the author.
  5. In the case of unauthorized copying, the verified author has the right to file a complaint and the administration of the website will immediately remove modification or copy of his/her work.*
*Complaints are considered only within the catalog of this website. Watch faces published on other resources are not taken into account and cannot be regarded as the original (primary source). All complaints can be considered within the branch where the work is published. If someone adapts your work for other watches, then there is a standard rule for such an issue, which is: the author who adapted someone's work must indicate the original author (source) in the description.
This group was created to distinguish and protect those authors, who spend a lot of time and energy on the design and creation of their own watchfaces. This means that watchfaces should not repeat either the style, fonts, background, etc. of other works on the website. The administration of the website also do not accept authors who have many similar works (copies of one and the same watchface with slight differences).
  1. You need to have a minimum of 5 completely different works uploaded on our website (Published separately).**
  2. Your works have to be designed by you and popular on the site.***
  3. All posted works should have a completed description and correct tags.
  4. The author should respond to comments under his/her work.
**Watchfaces that are ported from other watches or copies of watchfaces from famous brands of watches or smartwatches will be not considered.
***Popularity is determined by visitors of the website, i.e. such indicators as views, downloads, favorites are taken into account when considering.
Applications are processed within 7-14 days and the author receives a response in any case (either positive or negative).
Notice: After joining the group, you must update your watchfaces to receive a sticker (just enter the editing mode and re-save your watchface)
osmat
Admin
Has thanked: 35 times
Been thanked: 73 times
Post by osmat »
dinhlam91 wrote: 04 Sep 2020, 14:24
osmat wrote: 04 Sep 2020, 09:20
dinhlam91 wrote: 03 Sep 2020, 15:21
I've designed more WF, can you review again?
Good day. We select verified authors according to certain criteria. You don't go over a number of points.
Hello, What's the point I'm missing ?
We have criteria by which we select verified authors, you do not pass. Authors who remake other people's works cannot get into the group. This is the point of a group of trusted authors.
osmat
Admin
Post by osmat »
misterburnout wrote: 06 Sep 2020, 18:13
Hello. If possible I would join the group, too! Thanks :)
Thank you for your message. We are grateful for the contributions you made to the community. But we have to refuse you. The selection criteria for everyone are the same and we must be cold-blooded in this matter.
osmat
Admin
Post by osmat »
soyyo wrote: 04 Sep 2020, 12:20
Me gustaria estar dentro del grupo.
Gracias
Thank you for your message. We have to refuse you. And I ask you to pay attention to the fact that some of your work may be removed at the request of the copyright holder.
dinhlam91
Post by dinhlam91 »
osmat wrote: 07 Sep 2020, 09:33
Hello
>>>> I've created 5 completely different works uploaded in the website.
And remake some WF of other authors.
I think it's not an issue and it's not defined in the Rule.
Can you review it again?
osmat
Admin
Post by osmat »
dinhlam91 wrote: 08 Sep 2020, 02:39
Hello
We have checked all your works. But our answer is still the same. We are forced to refuse you. The rules specify a minimum that must be in order to consider an application to join the group. But meeting the minimum does not guarantee a positive answer.
josekso
Post by josekso »
Can I be a member of the group?
josekso wrote: 09 Sep 2020, 12:53
Done ✅
Govannon
Post by Govannon »
Hey all would like to be verified, have a few popular faces out there, cheers.
osmat
Admin
Post by osmat »
Govannon wrote: 12 Sep 2020, 00:24
Hello. Thank you for your request. But we are tired of rejecting your request.
jkmroczek
Post by jkmroczek »
I also would like to be verified author.
Best regards
rcdorrius
Post by rcdorrius »
Am I eligable to become verified author?
jkmroczek wrote: 14 Sep 2020, 23:06
Best regards
rcdorrius wrote: 15 Sep 2020, 08:04
Done. ✅
romius
Post by romius »
Hi, I want to join the contributor group.
osmat
Admin
Post by osmat »
romius wrote: 16 Sep 2020, 14:30
Done ✅
CrazyGavr
Post by CrazyGavr »
I make my own and redo others', can I become an author ?
osmat
Admin
Post by osmat »
CrazyGavr wrote: 18 Sep 2020, 22:40
Thank you for your message. But you do not match the criteria for the group of verified authors
sav2504
Post by sav2504 »
Please add me to the verified group.
sav2504 wrote: 28 Sep 2020, 20:06
Done ✅
Guydu91
Has thanked: 58 times
Post by Guydu91 »
Bonjour,
Puis-je être membre du Groupe ?
Merci d'avance.
Cordialement.
Drongo
Watchmen
Has thanked: 34 times
Been thanked: 12 times
Post by Drongo »
Guydu91 wrote: 02 Oct 2020, 05:56
Bonjour,
Merci d'avance.
Cordialement.
Done. ✅
Guydu91
Post by Guydu91 »
Merci beaucoup.
Cordialement.
Guydu91
Lues
Post by Lues »
Good afternoon, please add me to the group of verified authors. thanks..
osmat
Admin
Post by osmat »
Lues wrote: 11 Oct 2020, 11:14
Thank you for your request, but we have to reject it.
Drongo
Watchmen
Post by Drongo »
mrk_sbk wrote: 13 Oct 2020, 12:51
i would like to become a verified author.
Hello! You didn't read the rules!
svj3ist
Post by svj3ist »
I want to be a verified author.
