SupportUkraine
Our team decided to close the Verified Authors group due to the increase of controversial and negative situations and non-compliance with the rules by members of this group. From now on, we will stop accepting applications for membership. Though this is not the end, but the beginning of something new. Verified Authors group was created to protect and encourage original authors, but unfortunately, this idea stopped working. The rules and concepts of the group will be revised. Perhaps, some users will be excluded. We are now disabling the Verified Authors labels on all works, while the rules and benefits of the group continue to apply to all its members until we publish new information here. old rules
The works of such authors are marked with a special sticker (blue checkmark).
Advertising is not displayed for this group of authors.
An author may specify a link to PayPal or other ways to collect donations when uploading the work on the website.
Copying or modifying works of verified authors on our resource is possible only by agreement with the author.
In the case of unauthorized copying, the verified author has the right to file a complaint and the administration of the website will immediately remove modification or copy of his/her work.*
*Complaints are considered only within the catalog of this website. Watch faces published on other resources are not taken into account and cannot be regarded as the original (primary source). All complaints can be considered within the branch where the work is published. If someone adapts your work for other watches, then there is a standard rule for such an issue, which is: the author who adapted someone's work must indicate the original author (source) in the description.
This group was created to distinguish and protect those authors, who spend a lot of time and energy on the design and creation of their own watchfaces. This means that watchfaces should not repeat either the style, fonts, background, etc. of other works on the website. The administration of the website also do not accept authors who have many similar works (copies of one and the same watchface with slight differences).
You need to have a minimum of 5 completely different works uploaded on our website (Published separately).**
Your works have to be designed by you and popular on the site.***
All posted works should have a completed description and correct tags.
The author should respond to comments under his/her work.
**Watchfaces that are ported from other watches or copies of watchfaces from famous brands of watches or smartwatches will be not considered.
***Popularity is determined by visitors of the website, i.e. such indicators as views, downloads, favorites are taken into account when considering.
Applications are processed within 7-14 days and the author receives a response in any case (either positive or negative).
Notice:After joining the group, you must update your watchfaces to receive a sticker (just enter the editing mode and re-save your watchface)
I would like to apply for a verified author and will be humbly glad if got accepted. Thank you.
Some of your work is very similar to other work in the catalog.
Add a few more works, please. You have a lot of similar works, which it is desirable to combine into one (this is advice for the future).
But this is not your design. You even indicate this in the description of some of your works.
So how many more wf required to qualify me as verified author?
The main point of the Verified authors' group is to support those authors who make unique works by themselves. All of your works are supplemented or adapted designs taken from the other sources. They are not unique. Regarding the minimum quantity: you need to have at least 5 works that were completely designed by you.
Thanks for the advice. I will create more of my original design. Just keep an eye on my future work. Thank you.
I read the rules. my displays are copies of different brands. it's a pity. because i did everything myself.
If the copies are made from scratch is also not suitable?
Your works have to be unique (designed by you).
I counted. my unique works are exactly 5.
But this does not guarantee you access to the group. We give preference to authors, who in the majority publish their own work. Submit some unique WFs and resubmit your request.
These are my personal works. Shall I throw off the PSD files? Together with STEP formats?
I don't know how you check for uniqueness.
Please, do not try to prove anything. Five works is that minimum that the user needs to have for us to consider an application to join the group. Please note, that 5 works do not give you any guarantees that you will be immediately included in the group. I recommend you to publish a few more works and re-apply, after that we will consider your candidacy again.
Hello. We can't add you to the group of verified authors. Since your work does not meet her requirements. The resource administration's decision cannot be contested. We are sorry, but at the moment we recommend you to read the requirements for watchfaces again. We will be ready to review your re-request in a month at the earliest.
Some of your works are not unique * (The use of the names of famous brands/companies in the name, tags or description of the watch faces is not allowed), add some unique works and re-submit the application.
Cookie Consent
