• 管理员
How to make custom watch face for GTR?
版主: Internal errorWatchmens
主题已锁定
Volker Liebzeit
来自: Germany
联系:
帖子 Volker Liebzeit »
Hello, community,
I have just tried to get some information from this forum and I am very grateful that there is so much to read about my new Smartwatch Amazfit GTR 47 mm.
I have now tried to extract a bin file using the tool viewtopic.php?f=29&t=816&p=2313#p2313 offered here. I don't use original Watchfaces but custom Watchfaces already created by users like https://amazfitwatchfaces.com/gtr/view/2081. Unfortunately the error is always the same as shown in the picture. Can anyone help me with this?
Furthermore I read in the posts above my post how the packing/unpacking should work (if it works ;-) ). But how do I edit the unpacked files - so which tool do I use to do that ? Or is this really pure programming via json file text editor?
Thanks in advance for an answer.
Volker
附件
hikashi
Been thanked: 14 time
联系:
帖子 hikashi »
They are using python based tool.
The exe extractor is not up to date.
Volker Liebzeit
来自: Germany
联系:
That is the problem. I used python 3.8, newer than the specified one. But nothing happens...
hikashi
联系:
帖子 hikashi »
Try use different python tools
Im using dev-gtr py tools.. its stated in the same thread
Volker Liebzeit
来自: Germany
联系:
IThanks for your help, I have also tried several programs. The problem always occurs when I want to unpack Watchfaces with weather. The post says you need Python+pillow. This Pillow is the problem I think. I tried to install it but somehow it doesn't seem to work.
The yellow bar in my posted picture shows that there is a problem with the weather icons.
Well, then I just have to wait for you to put beautiful Watchfaces online again :)
头像
Lordalpine
来自: Santo Tirso
Has thanked: 6 time
Been thanked: 35 time
联系:
帖子 Lordalpine »
Volker Liebzeit 写了: 01 1月 2020, 05:29
Setup Python Tool environment
viewtopic.php?f=38&t=1110
SashaCX75Gui Tool No Python Version
Don't forget to Thank Dpeddi and SashaCX75 on 4PDA if you can^^
kampanita
Has thanked: 8 time
Been thanked: 7 time
联系:
帖子 kampanita »
I am using both methods and getting some WF that seem to be good but can not be installed at the GTR....
I thougth that i was caused by the size of pngs, but the size of .bin is only 1.467 kb so i that's not the problem.
Could be something related to "weather" ¿? it seems to create good bin files but they are not getting installed...
Any light will be thanked.
Matth78
来自: France
联系:
帖子 Matth78 »
Same here I have problems as soon as I try to add battery on my custom watchface.
watch996
来自: israel
联系:
帖子 watch996 »
and for verge lite too :-)
主题已锁定
回到 “Closed topics”
在线用户
正浏览此版面之用户: 没有注册用户 和 1 访客
