Haylou Solar Watchface Tool
osmat
Admin
Has thanked: 35 times
Been thanked: 73 times
Post by osmat »
Simple tool to pack and unpack .bin watchfaces for Haylou Solar
Important! To run this application, you also need installed .NET 5.0 Runtime.
WatchFace Tool Basic Tutorial for Haylou Solar
DedsecSD
Post by DedsecSD »
Can i set custom watch dial for imilab kw66 using haylou solar watch faces
osmat
Admin
Post by osmat »
DedsecSD wrote: 03 Mar 2021, 07:33
yes you can
Deel
Post by Deel »
Hi, can i use solar watchface for à "mibro air" , it use. bin files too, but use a . json and. dat in a zip files for the watchfaces.
Thanks for your answer.
osmat
Admin
Post by osmat »
Deel wrote: 03 Mar 2021, 23:09
not
worktgr
Post by worktgr »
thanks for this great tool
PozNashu
Post by PozNashu »
Nice tool, thank you!!!I just start to make my first watch face for my Solar LS05. :D
worktgr
Post by worktgr »
Hope for an update to this tool.
Problems I found
- weather and temperature not sync, maybe it's firmware problem
- icon steps animation doesn't run smoothly
Is it possible to arrange the order of element which one is at the front, example hours and minutes in front of connection.
KYR Watchfaces
Post by KYR Watchfaces »
worktgr wrote: 25 Mar 2021, 11:03
Problems I found
I think @osmat is not the developer of the tool, so he will not solve this problems.
The website for the tool, where you can find the e-mail of the developer to report bugs or send suggestions, is http://hswt.tilda.ws/
worktgr
Post by worktgr »
KYR Watchfaces wrote: 31 Mar 2021, 14:50
Problems I found
I saw it. New version 1. 1 is available to use after donation
Krzysieq
Post by Krzysieq »
how many $$ i must donate to v 1.1?
nick_fox123
Post by nick_fox123 »
Excuse me, I have a request. Can you share the new tool with me for free, v1.1
Has thanked: 1137 times
Been thanked: 275 times
nick_fox123 wrote: 16 Jun 2021, 06:04
https://amazfitwatchfaces.com/external/56
nick_fox123
GIK-Team wrote: 16 Jun 2021, 09:59
thank you very much
stevelbhui
Post by stevelbhui »
how to use animation speed?
BIGGBOSS
Post by BIGGBOSS »
Can I use Haylou Solar Watchfaces in Haylou RT LS05S ?? Experts plz Guide..!!
Aych38
Post by Aych38 »
Hello haylou için saat türkçe nasıl yapabilirim rt ls05s saati
kmzdotnet
Post by kmzdotnet »
stevelbhui wrote: 25 Jun 2021, 15:23
Actually it is FRAME DURATION, the calling "animation speed" is not suitable in this case. So if you set 1000, then each image in the animated element will displayed 1 second long. Just like the timeline in Adobe Photoshop.
Aych38
Post by Aych38 »
Merhaba haylou rt ls05s için tema var mi
Aych38
Post by Aych38 »
Lütfen yardım haylou ls05 temaları haylou rt ls05s nasıl yükleye bilirim
Sinaebz
Post by Sinaebz »
Hi. Please made tools for create HAYLOU RS3 watchface. Please
nick_fox123
hi, it is a great tool , can it support haylou
rs3 watch?
alihaider4670
Post by alihaider4670 »
osmat wrote: 03 Mar 2021, 09:24
yes you can
Hello sir,
Hope u have a bright day i just wanted to ask that will the Haylou Faces work on LS05s or is it just LSO5.
p.s : if i have file manager on Android 11 will the faces still work?
osmat
Admin
Post by osmat »
alihaider4670 wrote: 26 Nov 2021, 15:14
yes you can
Hello sir,
We have no such information. You can write a tool for the author to add your watch model
Noe156
Post by Noe156 »
How can you create a watch face with .tbwf format? Is there a tool like the one used for files with a .bin extension?
