Version 7.3
Fixed known display bugs.
v 7.2
v 5.0
v 4.1
v 4.0
v 3.1
Added French.
Added support for T-Rex Pro.
Found bugs fixed.
v 2.1
Fixed bugs in display AOD.
Added support for AOD.
Added Chinese translation.
v 1
Added English translation.
v 1.2 Added Spanish language
murmilega
Post by murmilega »
Hello everyone, could someone explain the process to convert or port a watch face from t-rex to t-rex pro? Thank you so much.
EDIT:
Thank you very much sasha, I had not seen the editor and sphere converter, thank you very much for your great work.
greetings
Version 4.0
demiurg1
Has thanked: 23 times
Been thanked: 17 times
Post by demiurg1 »
There is already version 4.0 of the SashaCX75 editor, for which we thank you. I did my last project on version 3.1. The next one will be in the new version. This last project is my little experiment with a "cheated" animation in GTR 2. I made a pseudo-animation of a bird flying in front of a weather image. This is obviously 1 frames per second and only 10 frames. You can see this project here: https://amazfitwatchfaces.com/gtr/view/15399.
Anyone who wants to can modify it in their own way!
Fringo
Post by Fringo »
Thank you for update! If you don't mind, I'd like to translate English into Korean(South)^-^
Jtkz
Post by Jtkz »
Hi SashaCX75 ,
I recently made a wf for gtr2 but when I test it on the watch the second hand seems to skip every second and only moves once every 2 seconds. There also seems to be a delay in waking the watch by clicking the button when using this watch face. This wf is much simpler and also smaller compared to my other watch faces so I'm not sure why this is happening. May I know if I did anything wrong with this wf?
The wf is attached below.
gtr2_junghans_maxbill_chrono full black_packed.bin
(221.98 KiB) Downloaded 193 times
Fringo
I do not plan to add translations to the editor, it is difficult to keep up to date version for many translations. And in the Korean language, as far as I know, the length of the inscriptions is very different from other languages and will need to be edited a lot. If you work with Visual Studio, you can translate the editor yourself.
Jtkz
You have a very large images with pointers. You need to crop empty areas on them.
Jtkz
Post by Jtkz »
Do you mean the pointer images themselves are too large?
Jtkz
Yes. There is a lot of empty space on them.
CASIONFAN2021
Post by CASIONFAN2021 »
Thank you sasha for the update. Its fantastic to have sunrise sunset now. There is no way to loaf any values into the sunrise sunset other than to click random values. I have noticed that when this is done the random values for the same function are random I.e if you have a circle and pointer at the same time you have to click random values a lot to get them to line up with each other making it tedious to check if the start angle of the pointer and the beginning angle of a circle and the end angle of pointer and circle are the same. Will there be an update to the values section to add start and finish time off the sunrise sunset. While it's not essential it would make life less random.
Ps the atmosphere barometer on t rex pro doesn't work with watch face after loading barometer on watch.
spidercrab
Has thanked: 27 times
Post by spidercrab »
@SashaCX75 Big thanks for the solid work on the new V4 editor. The new Rotated and Circle System text is a powerful new feature and well implemented.
Could I put in a furure request, to add access to more or all of the system fonts, if possible?
The current one is quite thin and there are some system fonts that look heavier and easier to read, such as the Workout Italic system font and the Timer font.
Using system fonts throughout a design could greatly simplify WF creation and also I assume, make a significant reduction in file size. (Assuming the system fonts are loaded directly from the WF firmware.)
CASIONFAN2021
The barometer does not work on the T-Rex Pro.
Sunrise and sunset times change every day depending on the city. Therefore, in the editor, I see no reason to customize it. In the editor, sunrise at 5:30 am and sunset at 7:30 pm. Progress is calculated based on the current time. But I do not recommend using progress. In addition to time, other display methods do not always work correctly.
spidercrab
The system font is in the firmware of the watch and cannot be changed using the dial.
gengtrex
Post by gengtrex »
is it still possible to have an animation on trexpro someday, according to its system?
cos it is making me hesitate to buy a trexpro if it seems impossible for that.
(now i am happy with animation on my original trex.)
thanks. :)
Reysonk
Post by Reysonk »
@SashaCX75 look here tap zone! https://amazfitwatchfaces.com/t-rex/view/5875
Has thanked: 419 times
Been thanked: 2109 times
Reysonk wrote: 07 Jun 2021, 19:52
That file BIN is not format T-rex pro. That BIN create by "AmazFit_Watchface_Editor_(GTR47ToGTR2)" or convert by "GTRtoGTR2" from T-rex , GTR , GTS
( you can see the program on the first post ) viewtopic.php?p=8392#p8392
if you unpack BIN and open the .json you will see the command line is a T-rex format. So BIN can use shortcuts.
You will notice that file convert by "GTRtoGTR2" or create by AmazFit_Watchface_Editor_(GTR47ToGTR2)" it doesn't have a custom AOD, and the weather icon has only 25 types + 1 icon "No data"
The size of the system font should not be more than 47, it can cause an infinite reboot watch.
vaibhthakur
Post by vaibhthakur »
Hello, is it possible to add the imagescount tab in the GTR2 software? I am trying to port a watchface from GTR 47 mm using the convertor and using the converted png image files to develop a watchface for gtr2 from scratch. Due to the unavailability of imagescount, it is taking in the values from the next pngs. Please tell me if there is a fix for this at the moment. Thanks in advance!
vaibhthakur
I don't understand why the "imagescount" tab is needed. All elements that allow you to change the number of images have such a parameter. In this version of the editor, it is called "Number of images"
vaibhthakur
SashaCX75 wrote: 13 Jun 2021, 19:13
@vaibhthakur
Okay got it! Thanks. The GTR2 has more weather icons so it took more values. I added them and it was good to go
AlexS85
Post by AlexS85 »
Возникла такая проблема: загружаю изображения в первой вкладке, но дальше во вкладке "Редактирование" программа не дает выбрать загруженные изображения :(
alex585
Количество загруженных изображений должно быть не менее 3.
Version 4.1
demiurg1
Post by demiurg1 »
SUPER :)
sfreud
Post by sfreud »
u can make it reverse when u can...gtr2 to 47/42 ,iamiam :D
Users browsing this forum: Google Adsense [Bot] and 13 guests
