Greetings,
I would like you to get me out of a doubt.
Is that I have a wf that works for Bit and Bit S, I yesterday created two publications, one for Bit and one for Bit S, from the same wf, but the system eliminated both publications, I do not understand why.
Basically what I want to know is what rule I broke so that the system would delete the publications. Today I created the post for the Bip again, but I don't dare to create the one for Bip S for fear that I will delete them again. Is there a problem in creating two publications of the same application with compatibility for different devices?
I thank you in advance for the help
Problem with publications [Bip]
- GIK-Team
- root
- Has thanked: 1108 times
- Been thanked: 267 times
Hello! Are you sure you filled in all the fields correctly? Have you added the correct preview?b-leet wrote: 29 Apr 2021, 20:43Greetings,
