Version 7.3
Fixed known display bugs.
v 7.2
v 5.0
v 4.1
v 4.0
v 3.1
Added French.
Added support for T-Rex Pro.
Found bugs fixed.
v 2.1
Fixed bugs in display AOD.
Added support for AOD.
Added Chinese translation.
v 1
Added English translation.
v 1.2 Added Spanish language
spidercrab
Has thanked: 27 times
Post by spidercrab »
Just wanted to say that I really hope that there are enough similarities between the T-Rex Pro and GTR 2(e), GTS 2 that eventually, the v2 WF Editor will have the capability to work with the T-Rex Pro.
Having used the v1 Editor with 42mm and 47mm GTR, I have total confidence in SashaCX75 to make this happen if it possible. SashaCX75 is a genius and has given so much to the Amazfit community..
I predict huge success for the T-Rex Pro.
ntnntp
I sometimes have problems installing watch faces. The following actions help:
1 Remove unnecessary watch faces from the watch.
2 Restart the watch.
3 Restart your phone.
If the id replacement did not work, then the dial would be installed but replace the already installed one. Therefore, the problem is not the replacement of id.
RufusLoacker
Post by RufusLoacker »
I'm looking into buying a GTR2e, and I wonder if it was possible to create a 24 hours analog watch face (where the hours hand makes one complete round in a day instead of two rounds).
Is this possible to code with this (or other) tool?
pic for reference:
No, the behavior of an analog clock cannot be changed.
synar
Post by synar »
Dear Sasha!
Just came the fresh firmware for the GTS 2e, and unfortunetely now already the weather alignment issue is arrived to this watch too. Only the left alignment is working properly now. I just want to inform you.
wing0826
Has thanked: 9 times
Post by wing0826 »
HI~everyone,
does it only have 12-hour clock in GTR2 watchface?
synar wrote: 07 Apr 2021, 19:52
Dear Sasha!
Thanks for the info. It will be necessary to check, maybe something else has changed.
GTRtoGTR2
Not all elements work after conversion. Of the advantages of such dials, I consider only working shortcuts and the ability to set different fonts and independent coordinates for tens and units in time.
spidercrab
This is very exciting.
Does this convert from GTR2 to T-Rex Pro? Or can I load a GTR47mm WF and convert to T-Rex Pro?
Also there are 2 versions in the 2 posts above. Which is the best to use?
Can convert T-Rex to T-Rex Pro
If you need to convert GTR47mm to T-Rex, you can do it in the editor for GTR47mm
Dials created by conversions from GTR47mm are not compatible with WatchFace editor 2. I have posted these programs here because they create dials for the same models as WatchFace editor 2. Further development of these programs is not planned and therefore I did not become a separate topic for them on the forum create.
jjkielce
Post by jjkielce »
Using the editor in version 2.1 I converted one of my GTS projects to GTS2 https://amazfitwatchfaces.com/gts/view/4826 and the user who downloaded the file reports a problem. It can install the watch face, the dial works fine, but if it tries to change the watch face on the clock, going back to W-Face won't work and needs to reinstall W-Face. I will be very grateful if someone checks this file on their GTS2 or if the designers check it in the editor. P.S. many thanks to SashaCX75 for creating this editor. efficient straight with great possibilities. Bravo
jjkielce
You have a 1 pixel preview picture. Make it a normal size.
To do this, just click Refresh Preview in the editor. and in the dialog box, select No.
jjkielce
Post by jjkielce »
SashaCX75 wrote: 13 Apr 2021, 09:28
@jjkielce
thanks for the reaction. I've already done it. I hope this will solve the problems and we will gain experience. Best regards and good health.
Rjonet
Post by Rjonet »
the program does not work for me, it starts perfectly, I unzip the file.bin and nothing appears, without any errors. help me please.
Rjonet
A folder with the bin file name should appear in the Watch_face folder. It should contain a log file. The bin file itself can also help figure it out.
Rjonet
Post by Rjonet »
Grazie
casio_f91w_47mm_zip.bin
(353.46 KiB) Downloaded 818 times
Rjonet
Post by Rjonet »
Grazie
fr_b_lr_gtr2-114463-e11ed767fe.bin
(5.39 MiB) Downloaded 760 times
Rjonet
The casio_f91w_47mm_zip.bin file is not from GTR2 and therefore is not unpacked by the editor.
The file fr_b_lr_gtr2-114463-e11ed767fe.bin is normally unpacked by the editor. If you are not, then try to update the framework to version 4.5, move the folder with the editor to the root of the disk and try again.
Check the Watch_face folder to see if there is a folder with the watch face name and a log file in it.
yakface
Post by yakface »
@SashaCX75
The tools you released have been really amazing. You mentioned that some of the elements do not work with the converter script. Some of the more complex WF with animations dont translate well but I noticed that the battery information consistently does not transfer. Is there a way to get that to work?
yakface
If the battery is displayed only in text, it works.
I suppose if one display mode is set for the battery, then it will work.
jjkielce
Post by jjkielce »
@jjkielce
the user confirmed that the shield is 100% functional. thanks. I will remember this lesson (it is not worth taking shortcuts and not saving the capacity of the watch here). Best regards and good health.
gengtrex
Post by gengtrex »
hi sasha.
i have tried to create T-rex Pro wf by your latest editor (GTS2 / GTR2 / Trex-pro).
everything looked perfect from beginning to packing.
but when uploaded from mobile to t-rex pro watch, it failed and just loaded the default wf.
can you give me some idea how i can fix this?
thanks a lot in advance. :)
tlausl
Post by tlausl »
gengtrex wrote: 21 Apr 2021, 05:45
@SashaCX75
hi sasha.
Same here.
gengtrex , tlausl
Users browsing this forum: No registered users and 32 guests
