Request watchface for gtr2
Moderatori: asoo, Watchmens
xakarion
Messaggio da xakarion »
Hi. Can someone change this watchface made by aliense for gtr47 with Polish language to gtr2? Thanks for your time
Also if it is possible can someone change this watchface made by asoo for gtr47 to gtr2 with Polish language?
Been thanked: 2090 times
Messaggio da asoo »
xakarion
Thanks for this watchface :) can someone change this first watchface too?
Messaggio da asoo »
digital_aliense_pl_GTRtoGTR2.bin
(172.12 KiB) Scaricato 56 volte
___________________________________________________________________________________________
This request is very simple, so in the first time I did not make it.
I think if you try converting it by yourself, it may add some fun to you.
If you interest you can find management tools at the link below.
viewtopic.php?p=8844#p8844
It just download BIN and use tool to convert just a few clicks can be done and ready to use.
Next time hope you fun to do it by yourself ;)
____________________________________________________________________________________________
xakarion
Thanks you so much ;) I will try do it myself next time
