Request watchface for gtr2
xakarion
Post by xakarion »
Hi. Can someone change this watchface made by aliense for gtr47 with Polish language to gtr2? Thanks for your time
Also if it is possible can someone change this watchface made by asoo for gtr47 to gtr2 with Polish language?
Has thanked: 440 times
Been thanked: 2142 times
xakarion
Post by xakarion »
Thanks for this watchface :) can someone change this first watchface too?
digital_aliense_pl_GTRtoGTR2.bin
(172.12 KiB) Downloaded 57 times
___________________________________________________________________________________________
This request is very simple, so in the first time I did not make it.
I think if you try converting it by yourself, it may add some fun to you.
If you interest you can find management tools at the link below.
viewtopic.php?p=8844#p8844
It just download BIN and use tool to convert just a few clicks can be done and ready to use.
Next time hope you fun to do it by yourself ;)
____________________________________________________________________________________________
xakarion
Post by xakarion »
Thanks you so much ;) I will try do it myself next time
