SupportUkraine
Hi, can i use solar watchface for à "mibro air" , it use. bin files too, but use a . json and. dat in a zip files for the watchfaces.
Thanks for your answer.
Hope for an update to this tool.
Problems I found
- weather and temperature not sync, maybe it's firmware problem
- icon steps animation doesn't run smoothly
Is it possible to arrange the order of element which one is at the front, example hours and minutes in front of connection.
Problems I found
I think @osmat is not the developer of the tool, so he will not solve this problems.
The website for the tool, where you can find the e-mail of the developer to report bugs or send suggestions, is http://hswt.tilda.ws/
Problems I found
I saw it. New version 1. 1 is available to use after donation
Actually it is FRAME DURATION, the calling "animation speed" is not suitable in this case. So if you set 1000, then each image in the animated element will displayed 1 second long. Just like the timeline in Adobe Photoshop.
Cookie Consent
