Has thanked: 14 times
Been thanked: 1043 times
Version 7.3
Fixed known display bugs.
v 7.2
v 5.0
v 4.1
v 4.0
v 3.1
Added French.
Added support for T-Rex Pro.
Found bugs fixed.
v 2.1
Fixed bugs in display AOD.
Added support for AOD.
Added Chinese translation.
v 1
Added English translation.
v 1.2 Added Spanish language
zecxzec
Post by zecxzec »
Thank you for your cooperation!!!
Can you add gts2 mini to new program??
Is it possible??
Anyway i respect your abilities!
zyfish
Post by zyfish »
thank you very much.
zecxzec wrote: 07 Mar 2021, 12:54
No. gts2 mini watch faces are different from gts2 watch faces. The unpacking utility used in the editor cannot work with gts2 mini watch faces.
demiurg1
Has thanked: 23 times
Been thanked: 17 times
Post by demiurg1 »
SashaCX75, Thanks for another great watch face editing tool. Previously I used the version for the GTR 47 and now I can for the GTR 2. Thanks again. I'd like to buy you a very large beer. If you lived in Poland, I probably could do it. :)
demiurg1
Post by demiurg1 »
A note was written "It is advisable to unpack the program to the root of the disk." I understand that the folder with the "AmazFit_Watchface_Editor_2" tool must be on the "C" drive in the root directory (folder). Is it only in it? Can a subdirectory be used?
demiurg1 wrote: 07 Mar 2021, 20:15
You can unpack it to another folder.
It's just that sometimes people created a lot of folders with long names and then there were problems. After that, such a warning appeared.
demiurg1
Post by demiurg1 »
OKAY. Thanks. I will use a folder with the short name "C: \ programs \ AmazFit_Watchface_Editor_2". If something is wrong, I will throw "AmazFit_Watchface_Editor_2" into the main folder and write about it.
demiurg1
Post by demiurg1 »
For SashaCX75
I just tried from the root directory (folder) and there was a problem. At this link I put a zipped file with the error information (LOG file).
https://www.dropbox.com/s/gkm7um6yehifk ... e.zip?dl=0
It will be there for a few days and then I will delete it
mickdu59
Post by mickdu59 »
hello, how to download it, you have a link for GTS 2 ? thank you
Has thanked: 429 times
Been thanked: 2132 times
mickdu59 wrote: 08 Mar 2021, 05:06
- Link download is in the first post ( click at "Version 1.1 " )
- you can select GTR2 GTS2 in the program
demiurg1
Post by demiurg1 »
Yes, the link to these versions is at the top of this post.
demiurg1
Post by demiurg1 »
Info for SashaCX75
It seems that the error I have shown is not a directory (folder) problem, but the error is due to the contents of the bin file. This is what it looks like after reading the LOG file to which I previously provided the link.
eliasf
Post by eliasf »
demiurg1 wrote: 08 Mar 2021, 10:03
Info for SashaCX75
You probably changed the folder name after unzipping all your files.
Either delete everything, then reinstall and do not change the folder name after reinstalling.
If the problem persists go into Settings.json in the root folder of the program and make sure this line:
  "pack_unpack_dir": "C:\\xxxxxxxxxxx\\Tools\\main.exe",
corresponds to your actual path.
wolfgangausw
Post by wolfgangausw »
Hello SashaCX75,
first of all thanks for the GTR2 editor.
My question is how to display the bluetooth status on the idl screen.
I tried to copy the bluetooth sector to the IDLE area. Unfortunately without success.
demiurg1
Make sure to extract all files from the archive. Go to the program settings and click the "Reset" button. Restart the program.
wolfgangausw
The watch displays the icon only when the bluetooth connection is broken.
Naddus
Post by Naddus »
Will there be a editor for gts 2 mini in future too? Or where can I found one? Thanks.
Naddus
Support for gts 2 mini watch faces is not planned.
KoltesPunti
Post by KoltesPunti »
Nice Job mate ;)
Is there a function for the Starimage on GTS2? (like on the gts)
wolfgangausw
Naddus
"The watch displays the icon only when the bluetooth connection is broken."
Yes, I lnow. I want to show the broken connection on the idle screen.
Pal57
Post by Pal57 »
Hi and thanks for the new app for GTR 2.
When making a new watch face from scratch, how can I put a new image, like a second hand png, without erasing all the other images.
It looks like every time I put a new image png it starts up new face.
MichaRe
Post by MichaRe »
Thank you so much Sasha :D :D :D !
KoltesPunti
If by "Starimage" we mean the image that appears when the goal of the steps is reached, then it is not yet known how to show it.
wolfgangausw wrote: 08 Mar 2021, 17:06
@Naddus
My editor doesn't support idle screen (AOD) yet. And, as far as I know, in this mode you cannot display status icons, including bluetooth.
Users browsing this forum: No registered users and 11 guests
