GTR 2e Watchfaces
by using Aw apps?eliasf wrote: 30 Jan 2021, 08:30I've tried many for GTR2 on my e and haven't had a problem yet, they all worked!
Aw apps keep tellling m to sync with the zepp!eliasf wrote: 30 Jan 2021, 08:30I've tried many for GTR2 on my e and haven't had a problem yet, they all worked!
ive already sync it , still no sucess to change WF
- eliasf
- Has thanked: 5 times
- Been thanked: 5 times
No the AW app doesn't work for me either.
Notify for Amazfit from playstore.
If you go into the far right tab there is a section Watchfaces and there you choose Amazfitwatchfaces.com and get all the options from AW, it's like a web UI inside the Notify app.
From there everything works.
Let me know if you succeed, otherwise I'll post some screenshots for you!
- AlterSchwede62
What? Where exactly should that be?
I have the GTR2 e and I do not see anything anywhere...
In the Watchfaces section of Zepp there isnt any Amazfitwatchfaces.com
What Notify App do you mean?
Can you add pictures?
Thanx.
Thanx.
- AlterSchwede62
Ah, I did not read the most important:
"Notify for Amazfit"
This is a very nice, little and very informing App, that allows uploading Watchfaces from here (Amazfitwatchfaces.com).
- eliasf
This is the app:AlterSchwede62 wrote: 14 Feb 2021, 17:09What? Where exactly should that be?
Thanx.
After you pair the app with your watch you need to go here:
Then you choose Watchfaces:
And then Amazfitwatchfaces.com:
Then you choose GTR2-GTR2e and install what you like!
Fulvio_61
- Has thanked: 1 time
I just ordered a GTR2, which I will use with IOS. Not having found "Notify for Amazfit" on Apple Store, I have to think that I will not be able to install Amazfitwatchfaces.com faces?
- mrlawrencelam
- Been thanked: 2 times
I have no problem installing GTR2 watch faces AmazFaces on my GTR-2e through syncing via AmazTools. If you are getting "Generic Error" repeatedly after many attempts, try to delete some existing faces in your watch.
