Install watchfaces to the GTS 2e (iOS)
When I try to install watchfaces from the GTS 2 section via the AmazTools app on iOS to my GTS 2e, the app says that my device is not supported for that watchface. Is that true? Are GTS2 and GTS2e watchfaces not compatible?
Patryk1027
I have the same problem with my GTS2, I can't install any watchface because the message "This file is not compatible with your device"
I found the solution on Reddit. When the error message shows up, simply tap on the three buttons in the upper right corner and choose "watchface". Then it will work. Just tried it with my GTS 2e!
