N1njaDerp
Post by N1njaDerp »
Hello, I have been having trouble with changing my files into a bin. I would really like some help.
Here is my error log:
Debug|Reading config...
Debug|Reading referenced images from 'D:\AmazfitBipTools-1.0.3\5b8f32a4dbe67_05092018'
Trace|Loading images for 2 'Background'
Trace|Loading images for 2.1 'Image'
Trace|Loading image 0...
Trace|Image was loaded from file D:\AmazfitBipTools-1.0.3\5b8f32a4dbe67_05092018\0000.png
Warn|Dithering applied for an image. Resource in watch face will use only supported colors. You can't get back original image by unpacking watch face.
Trace|Loading images for 3 'Time'
Trace|Loading images for 3.1 'TwoDigits'
Trace|Loading images for 3.1.1 'ImageSet'
Trace|Loading image 1...
Trace|Image was loaded from file D:\AmazfitBipTools-1.0.3\5b8f32a4dbe67_05092018\0001.png
Trace|Loading image 2...
Trace|Image was loaded from file D:\AmazfitBipTools-1.0.3\5b8f32a4dbe67_05092018\0002.png
Trace|Loading image 3...
Trace|Image was loaded from file D:\AmazfitBipTools-1.0.3\5b8f32a4dbe67_05092018\0003.png
Trace|Loading image 4...
Trace|Image was loaded from file D:\AmazfitBipTools-1.0.3\5b8f32a4dbe67_05092018\0004.png
Trace|Loading image 5...
Trace|Image was loaded from file D:\AmazfitBipTools-1.0.3\5b8f32a4dbe67_05092018\0005.png
Trace|Loading image 6...
Trace|Image was loaded from file D:\AmazfitBipTools-1.0.3\5b8f32a4dbe67_05092018\0006.png
Trace|Loading image 7...
Trace|Image was loaded from file D:\AmazfitBipTools-1.0.3\5b8f32a4dbe67_05092018\0007.png
Trace|Loading image 8...
Trace|Image was loaded from file D:\AmazfitBipTools-1.0.3\5b8f32a4dbe67_05092018\0008.png
Trace|Loading image 9...
Trace|Image was loaded from file D:\AmazfitBipTools-1.0.3\5b8f32a4dbe67_05092018\0009.png
Trace|Loading image 10...
Trace|Image was loaded from file D:\AmazfitBipTools-1.0.3\5b8f32a4dbe67_05092018\0010.png
Trace|Loading images for 3.1.2 'ImageSet'
Trace|Loading images for 3.2 'TwoDigits'
Trace|Loading images for 3.2.1 'ImageSet'
Trace|Loading image 11...
Trace|Image was loaded from file D:\AmazfitBipTools-1.0.3\5b8f32a4dbe67_05092018\0011.png
Trace|Loading image 12...
Trace|Image was loaded from file D:\AmazfitBipTools-1.0.3\5b8f32a4dbe67_05092018\0012.png
Trace|Loading image 13...
Trace|Image was loaded from file D:\AmazfitBipTools-1.0.3\5b8f32a4dbe67_05092018\0013.png
Trace|Loading image 14...
Trace|Image was loaded from file D:\AmazfitBipTools-1.0.3\5b8f32a4dbe67_05092018\0014.png
Trace|Loading image 15...
Trace|Image was loaded from file D:\AmazfitBipTools-1.0.3\5b8f32a4dbe67_05092018\0015.png
Trace|Loading image 16...
Trace|Image was loaded from file D:\AmazfitBipTools-1.0.3\5b8f32a4dbe67_05092018\0016.png
Trace|Loading image 17...
Trace|Image was loaded from file D:\AmazfitBipTools-1.0.3\5b8f32a4dbe67_05092018\0017.png
Trace|Loading image 18...
Trace|Image was loaded from file D:\AmazfitBipTools-1.0.3\5b8f32a4dbe67_05092018\0018.png
Trace|Loading image 19...
Trace|Image was loaded from file D:\AmazfitBipTools-1.0.3\5b8f32a4dbe67_05092018\0019.png
Trace|Loading image 20...
Trace|Image was loaded from file D:\AmazfitBipTools-1.0.3\5b8f32a4dbe67_05092018\0020.png
Trace|Loading images for 3.2.2 'ImageSet'
Trace|Loading images for 4 'Activity'
Trace|Loading images for 4.1 'Number'
Trace|Loading images for 4.1.5 'TextAlignment'
Trace|Loading image 21...
Trace|File D:\AmazfitBipTools-1.0.3\5b8f32a4dbe67_05092018\0200.png doesn't exists.
Trace|File D:\AmazfitBipTools-1.0.3\5b8f32a4dbe67_05092018\200.png doesn't exists.
Fatal|System.IO.FileNotFoundException: File referenced by index 200 not found.
at Resources.ImageLoader.LoadImageForNumber(String directory, Int64 index)
at WatchFace.Parser.Utils.ImagesLoader.LoadImage(Int64 index)
at WatchFace.Parser.Utils.ImagesLoader.Process[T](T serializable, String path)
at System.Dynamic.UpdateDelegates.UpdateAndExecuteVoid3[T0,T1,T2](CallSite site, T0 arg0, T1 arg1, T2 arg2)
at WatchFace.Program.WriteWatchFace(String outputDirectory, String outputFileName, String imagesDirectory, WatchFace watchFace)
paolino76
Post by paolino76 »
we need json file, you're referring to a file (0200.png) that doesn't exist
