- Amministratore
Will there be Amazfit Band 5 Support?
GiraffeMan3125
- Contatta:
I'm wondering if we could make watch faces for Amazfit Band 5 when it comes out, or if it already is out. If there are Mi Band 5 Watchfaces, then it should be possible to make faces for the Amazfit Band 5.
- GIK-Team
- root
- Has thanked: 1151 times
- Been thanked: 278 times
- Contatta:
It is not entirely clear where exactly you expect support.GiraffeMan3125 ha scritto: 28 set 2020, 00:24I'm wondering if we could make watch faces for Amazfit Band 5 when it comes out, or if it already is out. If there are Mi Band 5 Watchfaces, then it should be possible to make faces for the Amazfit Band 5.
andysoft83
- Has thanked: 3 times
- Contatta:
It means if we can use the Miband5 watchfaces on Amazfit Band 5 directly from the main mobile app, currently we cannot. The watch faces are the same , i manually uploaded on my Amazfit Band 5 a watchface for Miband5.
We want this to be done directly form the app, so please include Amazfit Band 5 in the devices list.
- GIK-Team
- root
- Contatta:
iOS or Android?andysoft83 ha scritto: 13 nov 2020, 12:15It means if we can use the Miband5 watchfaces on Amazfit Band 5 directly from the main mobile app, currently we cannot. The watch faces are the same , i manually uploaded on my Amazfit Band 5 a watchface for Miband5.
andysoft83
- Contatta:
andysoft83
- Contatta:
georgesmith
- Contatta:
Wow! Very Cool!andysoft83 ha scritto: 13 nov 2020, 20:22Here is Casio watchface on he new Amazfit Band 5, but like I said it was uploaded manually, from the Android app I cannot do it, I have selected Miband5 but doesn't work on this new Amazfit band, for the band I use the official Zepp app.
Thank you in advance dear dev team !
