Connection problems from Zepp to Amazfaces
Vicente martinez
Post by Vicente martinez »
Few day ago,I’m update amazfit app to zepp(iOS),
Then I can’t use AmazFaces app to change my watch face.
I don’t known what happen,and AmazFaces app show some word—-(Synchronize the watch with the MiFit/Amazfit application (open and check the MiFit/ Amazfit connection status))
phms
Post by phms »
Same here. Amazfit Bit S, fIrmware 2.1.1.50.
azhegu
Post by azhegu »
i got the same problem! from the notify app it works fine
Stas
Been thanked: 34 times
Post by Stas »
Update coming soon with fixes
Vpiaggio
Post by Vpiaggio »
Yesterday I received a new firmware of Amazfit GTR and after this I don’t get change the face.
The App gives the messege!
Synchronize the Watch with application.
But the AmazFaces is connected normal
Stas
Post by Stas »
Try to delete and re-bind the GTR in the AmazFaces or clear the application cache
Vpiaggio wrote: 01 Nov 2020, 14:48
Emmen
Post by Emmen »
I also have got the same problem. It doesn't help to re-bind my GTR, same error occurs. After restart of my iPhone the AmazFaces app crashes.
Lucky66
Post by Lucky66 »
hi
i have the same problem, have you a solution?
best regards
Sch
Post by Sch »
I have the same problem with my GTR. Upgrade to 1.3.7.17 and now way to change watchface. Try to unpair and then pair again, but does not help. Even restored factory settings but problem remains.
Some one knows how to fix?
benyukhis
Post by benyukhis »
Same issue here.... Will not install any watchfaces.
benyukhis
Post by benyukhis »
Works with T-Rex but does not appear to work with GTR. Is there anything in the works to address the issue, please?
Thank you,
EdB-
benyukhis
Post by benyukhis »
Any updates, please? Thank you
Birdbath199
Post by Birdbath199 »
Same issue here too GTR and app now crashes when install watch face - uninstalled reinstalled re binded ... mmm
frankraphael
Post by frankraphael »
After update, the app inform 49% is empty battery... I guess it need revision, and no synchronized with GTR 47mm
