Port my custom Pebble watchface to BIP Lite
bvlenci
Post by bvlenci »
Greetings, I just bought a BIP Lite, after mourning the demise of Pebble for several years.
I had designed several custom watchfaces for my Pebble. I still have the .json files. Would it be fairly easy to convert them to BIP Lite?
One of my favorite features on my main custom watchface was a display of the next two appointments on my Google calendar. The watch face showed time and date, these two appointments, phone battery %, watch battery %, and Bluetooth status. Nothing else. Are any of these variables not available for the BIP Lite?
Is there a list somewhere of available variables? Some standard icons?
Thank you very much.
SimsalaBip
Post by SimsalaBip »
Hi there,
I'm sorry - I don't think it is possible. The Pebble was a "real" smartwatch with a SDK and APIs. With enough knowledge you were able to do everything with it.
The BIP is kind of a better fitness tracker. You can build your own watchface with its own design but not with own functions. All functions are predefined and you can use them all or a part of them but you can't add own features.
And at this time there seems nothing included to realize what you want to create :-(
