MiBandWFTool
lvpokka
Has thanked: 19 times
Been thanked: 152 times
MiBandWFTool
Post by lvpokka »
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
lvpokka
Post by lvpokka »
deiG wrote: 19 Aug 2020, 23:33
Thanks for the really really great tool, @lvpokka! Is there a json template/example that contains all of the supported tags? For instance, I'd like a PAI progress indicator and I wonder if it is possible.
nope) i hope someone from followers will make such item) to get element, just download watchface with needed element, and copy json from it ;)
BTW> 2.1.5 released
diopter
Post by diopter »
"Time": "DelimiterImage" is still not displayed in preview.
  "Time": {
    "TimeDelimiterImage": {   //  visible in preview
      "X": 95,
      "Y": 168,
      "ImageIndex": 92,
    "DelimiterImage": {       //  NOT shown in preview
      "X": 0,
      "Y": 168,
      "ImageIndex": 92,
lvpokka
Post by lvpokka »
diopter wrote: 20 Aug 2020, 13:38
oh... forgot to pick this code for compile
upd.
Reuploaded
diopter
Post by diopter »
MiBandWFTool cannot unpack the MI stock WFs of the "Photo Watch Face" series (Style1 ... Style5).
The following error message appears in the log file:
Debug|Parsing parameters...
Trace|2 'Background'
Trace|2.1 'Image'
Trace|2.1.1 'X': 0
Trace|2.1.2 'Y': 0
Trace|2.1.3 'ImageIndex': 59
Fatal|System.ArgumentException: Parameter 6 isn't supported for Background
   bei WatchFace.Parser.Utils.ParametersConverter.Parse[T](List`1 descriptor, String path)
   bei MiCwU0e2dHM3cnc3H8.rC9cSqxd5BNoymSUH5.D5BJNoymS(Reader  )
lvpokka
Post by lvpokka »
diopter wrote: 21 Aug 2020, 00:32
Trace|2.1 'Image'
Trace|2.1.1 'X': 0
Trace|2.1.2 'Y': 0
Yes, it was not supported by purpose. It's not possible to get data from photo wface because its just a dummy and all compilations was performed on uploading to mi band 5
franluciani
Has thanked: 9 times
Been thanked: 6 times
Post by franluciani »
I saw in the official's WF for Mi Band 5, that the numbers can be turned. It will be nice if you can include this option in the tool
lvpokka
Post by lvpokka »
franluciani wrote: 21 Aug 2020, 12:20
didn't understand your message) add photos or something to help me understand
Do not understand, still
franluciani
Turned = gyrate = deranged
lvpokka
Post by lvpokka »
... Still not clear, but try to decompile it and check SpacingY & SpacingX, probably it help you
diopter
Post by diopter »
lvpokka wrote: 21 Aug 2020, 12:08
Are you sure that it's just a dummy?
I think that there is in the MB5 an overlay with a PNG with alpha blend to give all white pixels (except in the photo) the selected color.
It would be nice if it were also possible to easily change the colors of our custom WFs.
Could you do some research there?
After all, the error message indicates that there is an unknown parameter for "Background".
diopter
Post by diopter »
The bottom alignment bug in preview ist NOT fixed !
see viewtopic.php?p=6371#p6371
and viewtopic.php?p=6374#p6374
lvpokka
Post by lvpokka »
diopter wrote: 22 Aug 2020, 00:20
yeap, watchface is not containing background in itself(as it was in mi band 4), even if you uploaded it to mi band 5
also there is allot of images of position of elements, and it looks as configuration, not as builded watchface
franluciani
lvpokka wrote: 21 Aug 2020, 15:11
i got it and this help me. thx
diopter
Post by diopter »
"Alarm" - "ImageNoAlarm":
X and Y not working in preview, Image is shown always at text position
lvpokka
Post by lvpokka »
diopter wrote: 26 Aug 2020, 04:01
i need proofs, please upload images and protos of a problem,
also i need bin files with problem
diopter
Post by diopter »
"Alarm" - preview bug
"Text": OK
"ImageOn": OK
"ImageOff": OK
"ImageNoAlarm": The red line in my example should start at X=0 and Y=17, but starts at the position defined in "Text"
On MB5 all works like expected.
diopter_Test.bin
(2.72 KiB) Downloaded 269 times
diopter
Post by diopter »
Next preview bug:
"StepsProgress": - "CircleScale":
MB5 stops drawing the progress bar if "EndAngle" is reached, preview drawes around...
zyfish
Post by zyfish »
excuse me,Can AQI data be displayed on the MIBAND5? Only three animation files can be json? thanks.....
diopter
Post by diopter »
Suggestion for improvement:
The display of the MB5 has rounded corners.
It would be nice if the corresponding pixels were also set to black in the preview.
franluciani
Will be nice if the next version of tool adds some function to shortcuts, and other for modify the complications (as the original theme for Mi Band 5)
arthurking521
Has thanked: 7 times
Post by arthurking521 »
hi,
could u pls. modify a new tool based on the version of GTR-Watchface-editor,
The design is very convenient, intuitive, and has a “Shortcuts" function, you can click somewhere on the screen to enter the corresponding program. as franluciani mentioned
Thank you very much!
GTR-TOOL (2).jpg (198.72 KiB) Viewed 53685 times
lvpokka
Post by lvpokka »
arthurking521 wrote: 06 Sep 2020, 01:12
hi,
Do you have sourceCode of this program, i need real id of this Shortcut tag. Also need someone to test this element, because i dont want to brick my mi band 5 :D and i will not release it with out testing and proofs thats its working
arthurking521
lvpokka wrote: 06 Sep 2020, 18:09
hi,
I downloaded it from the post next door and applied it. Below is the download address,sorry I only know that
viewtopic.php?f=29&t=1076
schmitty782
Post by schmitty782 »
Hello. I have a little problem with the version "Mi Band 5 WF Tool v2.1.6".
I downloaded the following watchface:
https://amazfitwatchfaces.com/mi-band-5/view/577
I can extract it to JSON with no problems. But if I want to pack it back into the BIN without making any changes, I get the following error message:
"Fatal | [ERROR] Watchface is greater than 615kb, it will not be accepted by Mi Band 5, please reduce size! Current size: 724kb.
Fatal | System.ArgumentException: [ERROR] Watchface is greater than 615kb, it will not be accepted by Mi Band 5, please reduce size! Current size: 724kb.
at FBdrVENTOSQNAwAAQU.BV9w4uUq25cVnqdLQO.oSeohcXKw (string)
at FBdrVENTOSQNAwAAQU.BV9w4uUq25cVnqdLQO.J3lOPWa16aK5SHgjpf (Object)
at FBdrVENTOSQNAwAAQU.BV9w4uUq25cVnqdLQO.F4U4xmNtm (String []) "
Does somebody has any idea?
greeting
Christian
diopter
Post by diopter »
@schmitty782 :
Set "UsePaletteMode" value="1" in file WatchFace.exe.config
