Watchface bug!!!
Cavoli
Watchface bug!!!
Post by Cavoli »
Hi friends ,
I am CAVOLI , I have all the versions of mi bands . So yeah , I have a Mi band 4 CN / global version and also a Mi band 4 NFC version .
I have been using it for almost 7 months . In my Mi band 4 NFC , two weeks ago I synced one watchface .
You can check the watchface below , Its also available in bandbbs.cn
4days ago I updated my Mi band 4 NFC to v96 , in v93 it was all good. But this update really sucks . I also yesterday helped one of my freind [mention]hakpoid[/mention] .
Please help me , I am helpless . :|
The problem with this watchface is that I have used it in my Mi band 4 global version , it worked perfectly
Check this -
That awesome but in my Mi band 4 NFC I also synced that watchface but it comes black and white . Can anyone please help me ?? I know someday any one will help
Regards
CAVOLI ( Cavrio )
urieleugenio
Been thanked: 7 times
Post by urieleugenio »
Hi Cavoli,
Have you try flushing the memory on the band before syncing your WF again?
That worked for hakpoid. Just Sync a few WFs into the band (5 or 6 would probably be enough), before syncing back to your WF.
You can also try syncing 1 other custom WF from the AWFs site.
I read with MB5 the Tool sets the same ID to all WFs, so each custom WF rewrites the previous one.
I do not know if that's true for the MB4 Tool, but you can try changing to 1 custom WF and then going back to your WF.
Cavoli
Post by Cavoli »
urieleugenio wrote: 07 Aug 2020, 15:11
Hi Cavoli,
Thanks .
But how to flush my Mi bands memory ???
Please tell.
Do I have to do a factory reset ??
Thanks .
Regards
Cavoli
urieleugenio
Just Sync a few WFs into the band. Those new WFs will take up all the memory on the band, so that older WFs will be rewritten.
5 or 6 different WFs would probably be enough. After syncing those WFs, you can go back to your WF, and see if it works.
You can also try syncing 1 other custom WF from the AWFs site (not the ones from the MiFit store), and then going back to your WF.
Cavoli
Post by Cavoli »
urieleugenio wrote: 07 Aug 2020, 16:15
Thanks , it worked , really really thanks .
It was very helpful .
You are just awesome!!!!
urieleugenio
No problem, glad you got it working!
