Verified authors ✅ (OLD)
Has thanked: 1164 times
Been thanked: 279 times
Messaggio da GIK-Team »
Our team decided to close the Verified Authors group due to the increase of controversial and negative situations and non-compliance with the rules by members of this group. From now on, we will stop accepting applications for membership. Though this is not the end, but the beginning of something new. Verified Authors group was created to protect and encourage original authors, but unfortunately, this idea stopped working. The rules and concepts of the group will be revised. Perhaps, some users will be excluded. We are now disabling the Verified Authors labels on all works, while the rules and benefits of the group continue to apply to all its members until we publish new information here.
old rules
  1. The works of such authors are marked with a special sticker (blue checkmark).
  2. Advertising is not displayed for this group of authors.
  3. An author may specify a link to PayPal or other ways to collect donations when uploading the work on the website.
  4. Copying or modifying works of verified authors on our resource is possible only by agreement with the author.
  5. In the case of unauthorized copying, the verified author has the right to file a complaint and the administration of the website will immediately remove modification or copy of his/her work.*
*Complaints are considered only within the catalog of this website. Watch faces published on other resources are not taken into account and cannot be regarded as the original (primary source). All complaints can be considered within the branch where the work is published. If someone adapts your work for other watches, then there is a standard rule for such an issue, which is: the author who adapted someone's work must indicate the original author (source) in the description.
This group was created to distinguish and protect those authors, who spend a lot of time and energy on the design and creation of their own watchfaces. This means that watchfaces should not repeat either the style, fonts, background, etc. of other works on the website. The administration of the website also do not accept authors who have many similar works (copies of one and the same watchface with slight differences).
  1. You need to have a minimum of 5 completely different works uploaded on our website (Published separately).**
  2. Your works have to be designed by you and popular on the site.***
  3. All posted works should have a completed description and correct tags.
  4. The author should respond to comments under his/her work.
**Watchfaces that are ported from other watches or copies of watchfaces from famous brands of watches or smartwatches will be not considered.
***Popularity is determined by visitors of the website, i.e. such indicators as views, downloads, favorites are taken into account when considering.
Applications are processed within 7-14 days and the author receives a response in any case (either positive or negative).
Notice: After joining the group, you must update your watchfaces to receive a sticker (just enter the editing mode and re-save your watchface)
crixmas
Messaggio da crixmas »
Is it possible to pass in the verified authors?
Thank you.
Drongo
Watchmen
Has thanked: 34 times
Been thanked: 12 times
Messaggio da Drongo »
crixmas ha scritto: 23 giu 2020, 22:07
Thank you.
  1. You need to have a minimum of 5 works uploaded on our website (Published separately).
  2. Your works have to be unique (designed by you).**
crixmas
I uploaded 5 whacthface, they are all unique because they are designed by me
Drongo ha scritto: 23 giu 2020, 22:47
Thank you.
Drongo
Watchmen
crixmas ha scritto: 24 giu 2020, 06:44
Thank you.
So. The expression "unique work" means that it is one of a kind and not like any of the existing works. What do we see in your case? The first two dials are absolutely identical, with the exception of minor changes. The other three works use identical resources, such as font and widgets. I hope for your understanding and the early development of unique works so that we can add you to the group.
crixmas
I see. However, the dials made are unique, as they are not present on the site. The widgets you mean? steps, heart, calories
Drongo ha scritto: 24 giu 2020, 07:00
Drongo
Watchmen
crixmas ha scritto: 24 giu 2020, 11:42
The expression "unique work" means that it is one of a kind and not like any of your existing works. Do you understand?
Yes, in all of your watch faces, widgets are identical in appearance. So that you understand, in fact you have three unique works.
crixmas
perfect, now it's clearer. three unique works ok
Drongo ha scritto: 24 giu 2020, 13:47
GrayDoctor
Messaggio da GrayDoctor »
Hi, I want to come here)
GrayDoctor ha scritto: 28 giu 2020, 05:04
У Вас 4 работы имеют одинаковую структуру, разница лишь в фоне и шрифтах. Выражение «unique» означает, что оно единственное в своём роде и не похоже ни на одно из существующих.
justinao
Messaggio da justinao »
Hi, it would be great if I could also join to the Verified authors group.
justinao ha scritto: 01 lug 2020, 01:07
We added you to the group, but add a few more works, please. You have a lot of similar works, which it is desirable to combine into one (this is advice for the future). ;)
justinao
Thank you so much. I can ensure that new works will appear on my page. Have a nice day :)
crixmas
Now I should be there with the 5 exclusive watchfaces. It is possible to be included in the verified authors. Thank you
Ultima modifica di crixmas il 01 lug 2020, 12:28, modificato 1 volta in totale.
Drongo
Watchmen
crixmas ha scritto: 01 lug 2020, 12:26
You are in! ✅
crixmas
Thanks so much
Drongo ha scritto: 01 lug 2020, 13:19
You are in! ✅
GrayDoctor
GIK-Team ha scritto: 28 giu 2020, 08:40
Я шесть насчитал, и 1 в ми банд - есть еще на подходе ряд новых работ...
GrayDoctor ha scritto: 03 lug 2020, 06:06
Речь идёт именно о работах которые похоже одна на другую. У Вас есть все шансы попасть в группу, добавьте еще несколько работ.
ansary
Messaggio da ansary »
Can I join the group ?
GrayDoctor
Все надеюсь стать доверенным автором - может быть такое случится?)
Evgen18
Messaggio da Evgen18 »
Меня возьмете?
Drongo
Watchmen
ansary ha scritto: 05 lug 2020, 20:27
Drongo
Watchmen
GrayDoctor ha scritto: 06 lug 2020, 02:15
Может быть, уже случилось!
После присоединения к группе вы должны обновить свои циферблаты, чтобы получить стикер (просто войдите в режим редактирования и заново сохраните ваш циферблат)
Drongo
Watchmen
Evgen18 ha scritto: 06 lug 2020, 08:08
Меня возьмете?
Уже взяли!
Stezko
Messaggio da Stezko »
Меня возьмете?
Аналогично, желание попасть в эту группу!
Drongo
Watchmen
Stezko ha scritto: 06 lug 2020, 12:38
Меня возьмете?
Желание исполнено.
Bloccato
Torna a “Closed topics”
