SupportUkraine
Our team decided to close the Verified Authors group due to the increase of controversial and negative situations and non-compliance with the rules by members of this group. From now on, we will stop accepting applications for membership. Though this is not the end, but the beginning of something new. Verified Authors group was created to protect and encourage original authors, but unfortunately, this idea stopped working. The rules and concepts of the group will be revised. Perhaps, some users will be excluded. We are now disabling the Verified Authors labels on all works, while the rules and benefits of the group continue to apply to all its members until we publish new information here. old rules
The works of such authors are marked with a special sticker (blue checkmark).
Advertising is not displayed for this group of authors.
An author may specify a link to PayPal or other ways to collect donations when uploading the work on the website.
Copying or modifying works of verified authors on our resource is possible only by agreement with the author.
In the case of unauthorized copying, the verified author has the right to file a complaint and the administration of the website will immediately remove modification or copy of his/her work.*
*Complaints are considered only within the catalog of this website. Watch faces published on other resources are not taken into account and cannot be regarded as the original (primary source). All complaints can be considered within the branch where the work is published. If someone adapts your work for other watches, then there is a standard rule for such an issue, which is: the author who adapted someone's work must indicate the original author (source) in the description.
This group was created to distinguish and protect those authors, who spend a lot of time and energy on the design and creation of their own watchfaces. This means that watchfaces should not repeat either the style, fonts, background, etc. of other works on the website. The administration of the website also do not accept authors who have many similar works (copies of one and the same watchface with slight differences).
You need to have a minimum of 5 completely different works uploaded on our website (Published separately).**
Your works have to be designed by you and popular on the site.***
All posted works should have a completed description and correct tags.
The author should respond to comments under his/her work.
**Watchfaces that are ported from other watches or copies of watchfaces from famous brands of watches or smartwatches will be not considered.
***Popularity is determined by visitors of the website, i.e. such indicators as views, downloads, favorites are taken into account when considering.
Applications are processed within 7-14 days and the author receives a response in any case (either positive or negative).
Notice:After joining the group, you must update your watchfaces to receive a sticker (just enter the editing mode and re-save your watchface)
You need to have a minimum of 5 works uploaded on our website (Published separately).
Your works have to be unique (designed by you).**
So. The expression "unique work" means that it is one of a kind and not like any of the existing works. What do we see in your case? The first two dials are absolutely identical, with the exception of minor changes. The other three works use identical resources, such as font and widgets. I hope for your understanding and the early development of unique works so that we can add you to the group.
I uploaded 5 whacthface, they are all unique because they are designed by me
The expression "unique work" means that it is one of a kind and not like any of your existing works. Do you understand?
Yes, in all of your watch faces, widgets are identical in appearance. So that you understand, in fact you have three unique works.
У Вас 4 работы имеют одинаковую структуру, разница лишь в фоне и шрифтах. Выражение «unique» означает, что оно единственное в своём роде и не похоже ни на одно из существующих.
Hi, it would be great if I could also join to the Verified authors group.
We added you to the group, but add a few more works, please. You have a lot of similar works, which it is desirable to combine into one (this is advice for the future).
Я шесть насчитал, и 1 в ми банд - есть еще на подходе ряд новых работ...
Речь идёт именно о работах которые похоже одна на другую. У Вас есть все шансы попасть в группу, добавьте еще несколько работ.
Все надеюсь стать доверенным автором - может быть такое случится?)
Может быть, уже случилось!
После присоединения к группе вы должны обновить свои циферблаты, чтобы получить стикер (просто войдите в режим редактирования и заново сохраните ваш циферблат)
Уже взяли!
Желание исполнено.
Cookie Consent
