Arquivo sempre 0 k - quando vou baixar
vitormatematico
Galera fiz minhas mudanças, fiz o upload da imagem e o arquivo bin alterado, mas sempre que faço o downloads sempre vem zerado o que faço ? fiz o anexo do meu arquivo quem poder me ajudar agradeço e muito.
- Attachments
- thebrothers.bin
- o meu arquivo
- (21.4 KiB) Downloaded 78 times
- GIK-Team
- root
- Has thanked: 1112 times
- Been thanked: 267 times
in AmazFaces app on iOS?vitormatematico wrote: 13 Jun 2020, 03:15Galera fiz minhas mudanças, fiz o upload da imagem e o arquivo bin alterado, mas sempre que faço o downloads sempre vem zerado o que faço ? fiz o anexo do meu arquivo quem poder me ajudar agradeço e muito.
vitormatematico
- Lordalpine
- Has thanked: 6 times
- Been thanked: 35 times
Hi^^ got the same problem with my S8+ [Android 9 ] Exynos and my Note 10+ [Android 10] Snapdragon.
When i Try to download a face, the face is 77Kb instead of the right size.
So... when you I try to sync it.... It fails.
The workaround is to manually download the file on amazfitwatchfaces.com and manually replace it
On a computer the size is good, on an android browser [ Chrome ] the size is also ok.
The size is wrong only in the Android Apk.
- osmat
- Admin
- Has thanked: 35 times
- Been thanked: 73 times
What version of the application do you have ?Lordalpine wrote: 20 Jun 2020, 11:56Hi^^ got the same problem with my S8+ [Android 9 ] Exynos and my Note 10+ [Android 10] Snapdragon.
- Lordalpine
Hi^^ Osmat
Note 10+ [ Android 10 ]
Amazfit watchface App : Version 1.5 // Version 1.5 beta [ I tried Both on google play ]
Amazfit : Version 4.4.1-play
S8+ [ Android 9 ]
Amazfit : Version 3.7.0-play
It is so weird because, the problem is only with new watchface uploaded
The last one that work for me created by myself is the Apollo of
Uploaded: 07.06.2020 22:43
Updated: 08.06.2020 23:52
If I try to download and sync a face created the 12 and 13 of june it fails, I made one last week uploaded it here and tried to sync and it failed
So I have removed it thinking there was a problem on the face [ and didn't want to make problem to other users ]
I use mainly my own face on my watch... but seeing your message I tried face from other person, popular or not and the result is simple for me
If it's a fresh face, the size of the file is 77B [ It's not KB it's B... ] [ from me or other users ]
If the face is an older one like the A P O L L O 11 [ so before 12 june, the size is Ok and It syncs successfully ]
To try a face I like a lot : The T a g 0 2 Gold from Jubial [ Initial work from Maikeldevil ] mainly because the face is in Portuguese....
It Syncs succefully..... Uploaded: 16.04.2020 21:25
I have only Samsung Phone @ house.
Tomorrow I can test on my Dad's phone a Redmi note 9S [Android 10] with a GTR lite 47mm if it works [ It can affect only samsung Phone after all ] because Tomorrow in France It's "fathers Day" [ His gift is The GTR lite ]
Trying this is free so I will try^^
- Stas
- Has thanked: 4 times
- Been thanked: 34 times
What method is installed on the watch, replacement?Lordalpine wrote: 20 Jun 2020, 14:25Hi^^ Osmat
- Lordalpine
Hi^^ Yes File Swap on the Phone... [Copy to Watch_skin_local ]
File is downloaded by the App, when you check the size of file, it's only 77B.
- Stas
Thanks for the reply, tomorrow there will be a version with a fix in beta
Lordalpine wrote: 20 Jun 2020, 19:46Hi^^ Yes File Swap on the Phone... [Copy to Watch_skin_local ]
- Lordalpine
Hi Stas, problem is solved for me... the new beta version works.Stas wrote: 20 Jun 2020, 20:41Thanks for the reply, tomorrow there will be a version with a fix in beta
The problem with a 77B file is gone.
The download size is OK
The Face sync is OK
