New to Bip - HOw do I change the font size
I have an iPhone and thus can not use Gatgetbridge. Is there a way to get larger fonts for iPhone users?
manishareddy333
FWIW I'm on new FW version V1.1.6.48 and downloaded the BOLD_v6.9_9.ft.zip and used Gagetbridge to update the fonts. Works just fine. Funny the software vendor hasn't caught on or folks are not reporting this as an issue.
pidobeuliou
Yes, you're right. This is good.... but..... when you unpair from Gadgetbridge to pair your BIP to Amazfit app, the app restore the small font.GaryM wrote: 26 Apr 2020, 01:02FWIW I'm on new FW version V1.1.6.48 and downloaded the BOLD_v6.9_9.ft.zip and used Gagetbridge to update the fonts. Works just fine. Funny the software vendor hasn't caught on or folks are not reporting this as an issue.
This means, if you want to keep the bold font, you need to stay with Gadgetbridge.
And if you keep Gadgetbridge, you cannot anymore update your A-GPS... Not good.
I guess, we need a Bold font with signature of V1.1.6.48 to keep it when we switch back on Amazfit app...
Yep I experienced that as well.pidobeuliou wrote: 05 May 2020, 14:49I guess, we need a Bold font with signature of V1.1.6.48 to keep it when we switch back on Amazfit app...
BOLD_v6.15_9_spec.ft.zip is compatible with 1.1.6.48.
