AmazFaces APP (Android) open BETA
berilopassos
Dears, after installing the update for the AmazFaces beta App released yesterday, everything is working correctly. Developers, thank you very much for your support.
- osmat
- Admin
- Has thanked: 35 times
- Been thanked: 73 times
Without your feedback, we would not have done it! Thank you for trusting us.berilopassos wrote: 18 Feb 2020, 14:02Dears, after installing the update for the AmazFaces beta App released yesterday, everything is working correctly. Developers, thank you very much for your support.
Hi!, thanks for your work...
Can not download any watchface to GTS or T-Rex, when I press substitute to a local skin it does not do anything...First I had download a local stock skin to any of the smartwatches witout any problem and I gave AmazFaces app permissions to files.
Sorry for my English, as it is not my native language.
- osmat
- Admin
A small guide for interacting with watches through AmazFacesjmpnm wrote: 20 Feb 2020, 08:59Hi!, thanks for your work...
1.Turn on discovery in Amazfit.
2.Wait for synchronization.
3.Open AmazFaces and try the installation.
4.If the clock is still not connected.
5.Open the bluetooth settings.
6.Remove the watch from the list of paired devices.
7.Start at point 1
Important AmazFaces application must receive all permissions, including access to geolocation.
ThIs is a guide for Direct Instalation....does not work by that installation method, never connect to smartwatch. I was trying the other option on instalation method "Copy to watch_skin_local".osmat wrote: 20 Feb 2020, 21:19A small guide for interacting with watches through AmazFacesjmpnm wrote: 20 Feb 2020, 08:59Hi!, thanks for your work...
7.Start at point 1
EDIT: Ok, I got it, with " Direct Instalation" mode, on amazfaces app after pressing download I need to " start discovery" and then smartwatch is found and download firmare starts
- osmat
- Admin
jmpnm wrote: 21 Feb 2020, 13:23ThIs is a guide for Direct Instalation....does not work by that installation method, never connect to smartwatch. I was trying the other option on instalation method "Copy to watch_skin_local".osmat wrote: 20 Feb 2020, 21:19A small guide for interacting with watches through AmazFacesjmpnm wrote: 20 Feb 2020, 08:59Hi!, thanks for your work...
7.Start at point 1
In the example, I described one of the installation methods. The easiest in my opinion and 100% working
Guys how do i download and install a face using this app please
ravirajadke
Hi, it's not working with my Stratos either (direct installation, no app on the watch). I can't find this discovery mode you're talking about on the app. However, the watch is connected to the phone and synced. Then, when I try to install a watchface, it hangs for a while "initializing" and then fails. What am I doing wrong?
- osmat
- Admin
There is another way for stratos. With direct installation, the application runs on the wi fi watch. The phone should connect to this network and open Amazfit, after which the installation should go. Or you need to install the Amazfit service on your watch. https://amazfitwatchfaces.com/awappXouzouris wrote: 10 Mar 2020, 15:31Hi, it's not working with my Stratos either (direct installation, no app on the watch). I can't find this discovery mode you're talking about on the app. However, the watch is connected to the phone and synced. Then, when I try to install a watchface, it hangs for a while "initializing" and then fails. What am I doing wrong?
Or if you use Amazmod, you can install through it, just click share and select amazmod
LukasMoraes
[mention]osmat[/mention]
hi. i don't understand your answer. Do you can help me please? i have the same problem.
My phone and the watch are in the same wifi network, but they not sinc the AW app.
The message is "Somthing wrong wait 3-5 sec and retry install"
I'm using Stratos + Mi 9T PRO, both are updated to last version firmware.
Tks
___________________
LukasMoraes
Tks
___________________
LukasMoraes
LukasMoraes
hi. i don't understand your answer. Do you can help me please? i have the same problem.osmat wrote: 10 Mar 2020, 22:52There is another way for stratos. With direct installation, the application runs on the wi fi watch. The phone should connect to this network and open Amazfit, after which the installation should go. Or you need to install the Amazfit service on your watch. https://amazfitwatchfaces.com/awappXouzouris wrote: 10 Mar 2020, 15:31Hi, it's not working with my Stratos either (direct installation, no app on the watch). I can't find this discovery mode you're talking about on the app. However, the watch is connected to the phone and synced. Then, when I try to install a watchface, it hangs for a while "initializing" and then fails. What am I doing wrong?
Tks
____________
LukasMoraes
ok thank you
I had already app amazfit faces on my phone but how can i conncted my watch with it. i have amazfit pace watch
and how can i transfer the faces from the app into my watch
- osmat
- Admin
https://amazfitwatchfaces.com/awappNajimi wrote: 11 Mar 2020, 20:32ok thank you
davidbennelf29
Não está sincronizando com o gtr , está dando erro e não consigo usar mais nenhuma whatface do app
- osmat
- Admin
This happened after the last update ?davidbennelf29 wrote: 28 Mar 2020, 11:28Não está sincronizando com o gtr , está dando erro e não consigo usar mais nenhuma whatface do app
Eurico Lucas
- Has thanked: 1 time
Meu gt-r tbm não esta conseguindo trocar a face, toda vez q carrega 100% aparece erro de sincronização
- osmat
- Admin
Envie um screenshot.Eurico Lucas wrote: 03 Jun 2020, 19:39Meu gt-r tbm não esta conseguindo trocar a face, toda vez q carrega 100% aparece erro de sincronização
Adore_able
- Been thanked: 6 times
Thanks the app works perfectly on Android
Awesome!
Cheers!!!!
Awesome!
Cheers!!!!
Inspiring great affection and delight
GloriousMorningstar
It works to set a watch face in smart mode, but when I switch to ultra mode it changes back to a basic watch face.
- GIK-Team
- root
- Has thanked: 1127 times
- Been thanked: 267 times
It's normal.GloriousMorningstar wrote: 30 Aug 2020, 12:14It works to set a watch face in smart mode, but when I switch to ultra mode it changes back to a basic watch face.
