I need to know if any watch face shows or if I can add the status of the progress towards meeting the hourly idle target and if this target can be altered and if the vibrate to remind you can be altered.
Before I buy the Amazfit Bip I'm trying to find out how the idle fiction works. I have a Fitbit where it's set at 250 steps per hour with a vibrate, but the vibrate is very weak and the target cannot be altered.
Any advice would really be appreciated, thanks in advance.
Idle functionality
- SimsalaBip
- Has thanked: 1 time
I'm not sure if this is exacly what you need - you can set a reminder that vibrates when you're inactive for one hour within a specified time frame e.g. from 07h – 21h.
