I absolutely love this watch face. The only issue with it is the date format is opposite of what I'm used to. It should read FRI 3/6. Instead, it reads 6/3 FRI. Can someone please also change the distance from KM to Mi?
Also, could someone make a duplicate watchface that I requested, but with the weather icon removed? It updates so slowly or doesn't show the weather at all and it's annoying to see a blank weather icon. If someone can tell me how to fix the refresh rate, then I wouldn't need the icon removed.
Here is the original file:
https://amazfitwatchfaces.com/gtr/view/2308
Please change the date format on this face
Have you contact Original creator first, especially, you are asking people to duplicate other's creation!
You can always make donation to the creator and ask customization.
In addtion, I don't believe there is weather icon in the design you linked.
There's weather on the face I'm using. I did contact the creator via PM. I haven't received a response.
999Nocturne
- Has thanked: 2 times
