files explorer
Bloccato
dapownz91
files explorer
Messaggio da dapownz91 »
hello every one
i cant go in the files explorer to add some wallpaper on amazfit GTS
my computer cant find the device.
i try to reset watch
i try to other USB port
but nothing works.
can some one have a solution?
Regards
ionut02
Messaggio da ionut02 »
The only way to add something similar to a wallpaper on the GTS is either by setting a custom watch face through the Amazfit app (profile>amazfit GTS>watch face setting and then Custom in the top tab), or creating your own custom watchface and upload it through Notiffy&Fitness, Tools&Amazfit or MiBandage. The GTS is just a xiaomi Mi Band with larger display and GPS, it's not a smartwatch, you don't have access to internal display and you can't install apps.
Bloccato
Torna a “Closed topics”
Visitano il forum: Nessuno e 6 ospiti
