Can't connect MiBand4 to the app
scanferr
Post by scanferr »
Since couple of weeks ago I can't connect the band to the app. Shows some kind of location permission error but all permissions are enabled.
Any ideas?
kageroh
Post by kageroh »
I'm having the same problem and would appreciate a fix.
osmat
Admin
Has thanked: 35 times
Been thanked: 73 times
Post by osmat »
If you have android 10 you need to give constant access to geolocation
