MiBandWFTool
lvpokka
Has thanked: 19 times
Been thanked: 152 times
MiBandWFTool
Post by lvpokka »
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
ValeCrafter
Post by ValeCrafter »
lumenvindex wrote: 02 Nov 2019, 16:33
ValeCrafter wrote: 02 Nov 2019, 16:28
it stays still.
Current MiBand firmware plays animation only when Speed parameter isn't less than 4.
Okey thanks you, but now it shows the image only for a frame (maybe 100ms) and after that it disappears. The date and day disapear as well.
Regards
ValeCrafter
ValeCrafter
nite wrote: 08 Nov 2019, 00:58
Can someone tell me which folder to put the modified .bin file into? :/
Unfortunately, the "corresponding directory " part of this message means nothing to me. "Copy the newly generated bin file to the corresponding directory of the mobile phone"
There is an app in the Play Store ,where you can pic a .bin file from any folder from your phone and create a watch face perfect for Mi Fit.
The app is caled: MiBand4
In the menu there is the option to ad a watch face to Mi Fit. You have to load the .bin and .png file on your phone and choose them in the app.
Regards
ValeCrafter
lumenvindex
Been thanked: 49 times
Post by lumenvindex »
ValeCrafter wrote: 08 Nov 2019, 13:27
It's digital seconds. You can't use them (on current firmware) without losing everything but time digits. Analog seconds will only wipe animation and "heart scale".
MESS WITH THE BEST
DIE LIKE THE REST
lvpokka
Post by lvpokka »
Someone asked for miles support, in 1.4.2 added support for miles image for Distance
impoppy
Post by impoppy »
Would it be possible to add an Alarm indicator? Kinda like Bluetooth, just to show if your alarm is on or off.
franluciani
Has thanked: 9 times
Been thanked: 6 times
Post by franluciani »
Hi. I use the version 1.4.1 to create WF. But when i try to install in MiBand4 the WF is pixelated and the battery, steps, and letters are smaller. I think that the WFTool 1.4.1 scale the images 1.3x. Anyone happens the same?
lvpokka
Post by lvpokka »
Check DPI of images, thats the problem
Devnull
Post by Devnull »
Please help me! all png = 76KB :(
Fatal|[ERROR] Watchface is greater than 321kb, it will not be accepted by Mi Band 4, please reduce size! Current size:1567kb.
Fatal|System.ArgumentException: [ERROR] Watchface is greater than 321kb, it will not be accepted by Mi Band 4, please reduce size! Current size:1567kb.
em WatchFace.Program.PackWatchFace(String inputFileName)
em WatchFace.Program.Main(String[] args)
lumenvindex
Devnull wrote: 21 Dec 2019, 02:35
all png = 76KB :(
Images are not stored in png after packing. Try using PaletteImageMode.
MESS WITH THE BEST
DIE LIKE THE REST
tia_lenzi
Post by tia_lenzi »
Hi, i tried to edit a watchface, once done i created the .bin file, but i can't install it on mi Mi Band 4; it don't even start (i use AmazTools). Can someone help me please?
i enclose the file...
tia_lenzi watch face.bin
(516.22 KiB) Downloaded 160 times
Devnull
Post by Devnull »
TNKS
dilomo
Post by dilomo »
Is there any place we can see the source code of the tool for mi Band 4?
sahilahmed
Post by sahilahmed »
i have tried every thing possible but still the thing is saying the file is to big reduce size plz help
lvpokka
Post by lvpokka »
use palette mode
remove colors
save in paint as 8 bit
lower images count
NinjaBreadMan
Post by NinjaBreadMan »
Is there anyway to rotate Steps, box? it seems to have different arguments to date and time? seems to be treated as a whole number instead of separate digits.
thanks
Jackall Digital
Been thanked: 14 times
Post by Jackall Digital »
Hey all. I have a problem that I just can't seem to find a solution to.
I'm using the latest MiBandWFTool (1.4.2) in RawImageMode. My images are 72dpi, except for probably the background which I've saved with the Paint program. The Mi Band Firmware is v1.0.7.60 if other info is needed please let me know.
My problem is that if I leave my .bin with only steps and pulse under status it works, but as soon as I add distance or calories nothing of the "steps, pulse, distance, calories" shows up on mi band 4. Regardles of what I put in my .json everything is visible in the preview (although the preview is squished and doesn't represent my actual positioning of the elements - which is a bummer as I've wasted a lot of time blindly relying on the preview).
Is there a specific order these statuses should be put into the json or what am I missing? Also shouldn't the bluetooth icon be on when there is no connection to the phone, currently it's the other way around.
Adding both or any of the 2 statuses below into my json somehow breaks the miband4 from showing any of the stats.
    "Distance": {
      "Number": {
        "TopLeftX": 24,
        "TopLeftY": 196,
        "BottomRightX": 74,
        "BottomRightY": 212,
        "Alignment": "Left",
        "Spacing": 0,
        "ImageIndex": 21,
        "ImagesCount": 10
      "DecimalPointImageIndex": 99
    "Calories": {
      "Number": {
        "TopLeftX": 24,
        "TopLeftY": 220,
        "BottomRightX": 74,
        "BottomRightY": 236,
        "Spacing": 1,
        "ImageIndex": 21,
        "ImagesCount": 10
Much appreciated for any info anyone might have.
EDIT:
After some more brainstorming and looking carefully through other scripts I got it working. I don't know what "BoxWidth" and "Order" under DoNotDisturb, Lock, Bluetooth and Battery do, but I had them set to 1, after changing them to 0 now both distance and calories are displayed in my miband 4.
Great tool, will probably make more watch faces and I am looking forward to update my skin once the weather function becomes available.
clean_mi_face.bin
(286.2 KiB) Downloaded 176 times
Caz
Post by Caz »
Hi
i have been having the same problem, steps and pulse work great but when i add distance/miles the pulse disappears, no matter what i try i cant get all 3 ( steps pulse distance ) to show at the same time
lvpokka
Post by lvpokka »
Just checked builder code, so if your using Miles image, MiBand4 is requiering also KM image or it's crashing... please use the same image for KmSuffixImageIndex index :lol:
    "Distance": {
      "Number": {
        "TopLeftX": 40,
        "TopLeftY": 185,
        "BottomRightX": 78,
        "BottomRightY": 198,
        "Alignment": "TopCenter",
        "Spacing": 1,
        "ImageIndex": 31,
        "ImagesCount": 10
      "KmSuffixImageIndex": 31,
      "DecimalPointImageIndex": 121,
	  "MilesSuffixImageIndex": 31
Caz
Post by Caz »
brill thanks that works, i now have steps pulse and distance in miles
unfortunaty i think i have done something wrong as i still have a prob, my miles reads as 2.360 ect
i have 4 numbers where i would have thought it should read more like 2.3 or 2.36
any idea what i have done wrong?
thanks
caz
Dragos
Post by Dragos »
neither variant (raw or palette) creates .gif or .png files that can be uploaded to the site
Jackall Digital
Dragos wrote: 24 Jan 2020, 15:15
Then something is most likely wrong with the .json file, dont' know what exactly but I too had that issue where it was creating the .bin file but no preview png or gif.
You can check in the .log file if there is any clue as to what might be wrong otherwise you can test if your .json file is good by using another watch face that uses the same elements (so you don't have to make any changes) and use your json to create the bin. And of course you can use the json from the downloaded json to test your images.
dzsergio
Post by dzsergio »
hi i have a problem in generating wf,
png files (numbers and charachters) became bigger (zoomed in) in the generated wf
working with the 1.4.2 tool
tried changing dpi to 72dpi, same problem
lumenvindex
dzsergio wrote: 06 Apr 2020, 12:48
96 dpi is needed.
MESS WITH THE BEST
DIE LIKE THE REST
dzsergio
Post by dzsergio »
lumenvindex wrote: 06 Apr 2020, 14:12
96 dpi is needed.
thank you i didn't know that so i had to batch change dpi , i was to lazy to reexport xD, why should it be 96dpi?
can u make it higher?
lumenvindex
dzsergio wrote: 07 Apr 2020, 10:14
Mi Band ignores dpi anyway. You need it to be 96 to get nice preview, that's all.
MESS WITH THE BEST
DIE LIKE THE REST
