Does not replace the clock face.
Csernus
Post by Csernus »
Does not replace the clock face. Latest software and latest firmware. 47mm.
I reinstalled everything even the clock.
If you replace it with the default.
It has been doing so ever since the beta is up.
Can somebody help me? Will there be any updates in the near future?
Drongo
Watchmen
Has thanked: 34 times
Been thanked: 12 times
Post by Drongo »
If you use Amazfit, then at the time of replacing the dial, try to close Amazfit on the phone.
Csernus
Post by Csernus »
I have the same problem . Whatever I put in the dial always goes back to the default watchface.
sachinashokin
Post by sachinashokin »
Same here
Aferraz
Post by Aferraz »
Yep, my GTR 47 suffers from the same, since last update 2 days ago, I cannot instal any face from Amazfaces.
Please solve this issue ASAP.
masterz
Post by masterz »
I tough I was the only one 🥴
meszilaci
Post by meszilaci »
Unfortunately same here
Laza
Post by Laza »
same here
Error: 'Not found file in the folder'
Ramsoc2
Post by Ramsoc2 »
Same here, it shows the "sucess message" but returns to the default face.
When i try to choose from the watch it shows only the 2 default faces... Already tried to remove from the Amzfit, resync, factory reset...
Kagu
Post by Kagu »
Same here. Success, but returning to stock face. Tried uninstall reinstall, beta, non beta. Nothing helps. Waiting fix.....
ermanitu
Post by ermanitu »
Same here. Some watch faces work, but a lot of them not. Last update of Amazfit (3.4.7) helps (a few more watch faces work) but still some others fail.
ermanitu
Post by ermanitu »
I guess I've found a workaround: do not load watch face from AmazFaces, but from the Files App. The process working for me is:
- Found the watch face in Safari.
- Download it (to Files / iCloud / Downloads folder).
- Open Files and select downloaded file.
- Select Share with, and send it to AmazTools.
- Install.
I've tried with some problematic watch faces and now all is ok.
I guess the problematic app is AmazFaces.
Has thanked: 1164 times
Been thanked: 279 times
We are already working on a new version of the AmazFaces, soon everything will work ;)
ib12
Post by ib12 »
GIK-Team wrote: 01 Dec 2019, 14:11
Any idea on when the new version will be ready?
ib12 wrote: 02 Dec 2019, 14:47
Our developers are already working on it. As soon as possible.
basidz
Post by basidz »
Started another post but I have the same problem. Tried everything, install MInfit instead of amazefit but doesn't work either. Hope there is a solution fast,loved the watchfaces from this apl
Monkey Face
Post by Monkey Face »
Same problem here, after latest update (which I installed Dec 1 2019). Although prior to this latest update, I was able to replace stock watch faces with User-developed from Amazfitwatchfaces , Clearly a software problem with the update. I look forward to a fix, as without ability to replace stock faces, this watch becomes of little use. I do love the watch (prior to this software problem), and it is my favorite, even preferred to the best of Samsung, Huawei, which I also, own.
Darksymphony
Post by Darksymphony »
with the last update 1.2 I have the same problem . Whatever I put in the dial always goes back to the default watchface
sergstor
Post by sergstor »
The same case.
Gigs11
Post by Gigs11 »
Ne pomaže ništa sve postavke su kao na pocophonu na kojem aplikacija radi...aplikacija ne radi,xiaomi mi9
Gigs11
Post by Gigs11 »
Ne radi ovo ništa,nakon deset ažuriranja opet ne radi,vjerojatno ne znate popraviti
osmat
Admin
Has thanked: 35 times
Been thanked: 73 times
Post by osmat »
Melmers
Post by Melmers »
I had this problem too.
I found it is important to rename your new watchface .bin file to the name of the old watchface in the folder.
This requires you to;
1: copy the name of the original watchface .bin file
2: delete the original watchface file
3: rename your new watchface .bin file to match the original file name
That way you will notice it does not download the original watchface file again.
It will start syncing the watchface immediately.
This even works with my GTR Lite, which I initially thought was not supported.
osmat
Admin
Post by osmat »
It's in the manual. viewtopic.php?f=14&t=783
Or you can just use our application
