- Адміністратор
Does not replace the clock face.
Модератори: Internal error, Watchmens
Does not replace the clock face. Latest software and latest firmware. 47mm.
I reinstalled everything even the clock.
If you replace it with the default.
It has been doing so ever since the beta is up.
Can somebody help me? Will there be any updates in the near future?
I have the same problem . Whatever I put in the dial always goes back to the default watchface.
sachinashokin
- З нами з: 16 вересня 2019, 15:26
- Контактна інформація:
Yep, my GTR 47 suffers from the same, since last update 2 days ago, I cannot instal any face from Amazfaces.
Please solve this issue ASAP.
Ramsoc2
Same here, it shows the "sucess message" but returns to the default face.
When i try to choose from the watch it shows only the 2 default faces... Already tried to remove from the Amzfit, resync, factory reset...
Same here. Success, but returning to stock face. Tried uninstall reinstall, beta, non beta. Nothing helps. Waiting fix.....
ermanitu
- З нами з: 16 листопада 2019, 11:35
I guess I've found a workaround: do not load watch face from AmazFaces, but from the Files App. The process working for me is:
- Found the watch face in Safari.
- Download it (to Files / iCloud / Downloads folder).
- Open Files and select downloaded file.
- Select Share with, and send it to AmazTools.
- Install.
I've tried with some problematic watch faces and now all is ok.
I guess the problematic app is AmazFaces.
- Install.
- GIK-Team
- root
- З нами з: 22 березня 2018, 10:00
- Has thanked: 1155 times
- Been thanked: 278 times
We are already working on a new version of the AmazFaces, soon everything will work
Any idea on when the new version will be ready?GIK-Team писав: 01 грудня 2019, 14:11We are already working on a new version of the AmazFaces, soon everything will work![]()
- GIK-Team
- root
Our developers are already working on it. As soon as possible.
Started another post but I have the same problem. Tried everything, install MInfit instead of amazefit but doesn't work either. Hope there is a solution fast,loved the watchfaces from this apl
Monkey Face
- З нами з: 02 жовтня 2019, 00:49
Same problem here, after latest update (which I installed Dec 1 2019). Although prior to this latest update, I was able to replace stock watch faces with User-developed from Amazfitwatchfaces , Clearly a software problem with the update. I look forward to a fix, as without ability to replace stock faces, this watch becomes of little use. I do love the watch (prior to this software problem), and it is my favorite, even preferred to the best of Samsung, Huawei, which I also, own.
Darksymphony
- З нами з: 26 листопада 2019, 17:22
with the last update 1.2 I have the same problem . Whatever I put in the dial always goes back to the default watchface
- osmat
- Admin
- З нами з: 22 березня 2018, 10:09
- Has thanked: 35 times
- Been thanked: 73 times
Melmers
- З нами з: 02 квітня 2020, 05:20
I had this problem too.
I found it is important to rename your new watchface .bin file to the name of the old watchface in the folder.
This requires you to;
1: copy the name of the original watchface .bin file
2: delete the original watchface file
3: rename your new watchface .bin file to match the original file name
That way you will notice it does not download the original watchface file again.
It will start syncing the watchface immediately.
This even works with my GTR Lite, which I initially thought was not supported.
- osmat
- Admin
Хто зараз онлайн
