Cannot install watchfaces
Hello
I have a new gtr 42mm and iphone xs with last ios 13. I cannot install watchfaces downloaded from amazfaces app, i have followed the instruction but i always get an error.
Any idea on what to do?
- GIK-Team
- root
- Has thanked: 1105 times
- Been thanked: 266 times
Mifit or Amazfit?MF1970 wrote: 14 Oct 2019, 08:43Hello
- GIK-Team
- root
Open the companion program for watches that you use (Amazfit). Go to the tab with watch faces and install any of the stock. If you have already installed one you may miss the previous step and go straight to the AmazFace application.
Select your favorite watch face and click download. In the window that appears select Amazfit. The application will show a preview of that watch face which file needs to be replaced. Click Replace.
Now go to Amazfit and set the same watch face. Wait for installation, as it may take some time.
Please note, that after updating or clearing temporary data, watch faces files downloaded to the Amazfit folders may be deleted. If the AmazFace application has stopped installing watch faces, just follow the procedure for installing the stock watch faces.
Are you sure? The section of gtr on amazfaces says just “gtr 42/46 mm” and it was not clear for me the 42 mm faces are not available...Do you know where i can find faces for the 42 mm version?
- GIK-Team
- root
We are working on it.
Instructions as explained here did not work for me. Using verge lite on mifit. The same watchface I selected in mifit just shows up again. No error or debug message. Where/how can I see what is wrong?
- GIK-Team
- root
At the moment, we are solving numerous problems due to the fact that standard applications break compatibility.Taggy wrote: 23 Oct 2019, 07:56Instructions as explained here did not work for me. Using verge lite on mifit. The same watchface I selected in mifit just shows up again. No error or debug message. Where/how can I see what is wrong?
Users browsing this forum: Amazon [Bot] and 2 guests
