• Administrador
MiBandWFTool
Regras do fórum
lvpokka
Registrado em: 07 Jul 2019, 20:22
Has thanked: 19 times
Been thanked: 152 times
Contato:
MiBandWFTool
Mensagem por lvpokka »
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
Editado pela última vez por lvpokka em 02 Ago 2020, 19:41, em um total de 24 vezes.
Sonpham1710
Registrado em: 21 Set 2019, 11:00
Contato:
Mensagem por Sonpham1710 »
Help me move to bin file
1d rv. ms/u/s!AiC4WsYy1-I5wUWW_kiiFjRjSWrH?e=McwNDo
delete space
Avatar do usuário
Maikeldevil
Registrado em: 17 Ago 2019, 12:05
Been thanked: 44 times
Contato:
Mensagem por Maikeldevil »
Sonpham1710 escreveu: 10 Out 2019, 08:26
delete space
Have you seen your question? I really dont understand what you want..
Avatar do usuário
lumenvindex
Registrado em: 08 Set 2019, 19:01
Been thanked: 49 times
Contato:
Mensagem por lumenvindex »
Help me
Código: Selecionar todos
Watchface is greater than 321kb, it will not be accepted by Mi Band 4, please reduce size! Current size:2752kb.
Your animation frames are way too large. You need to animate only 26*10 pixels but your frames are 120*240. Cut off all unnecessary pixels, move the frame by editing your json here:
  "Other": {
    "Animation": {
      "AnimationImage": {
        "X": 0,      <----------------------------
        "Y": 0,      <----------------------------
MESS WITH THE BEST
DIE LIKE THE REST
Kierian
Mensagem por Kierian »
I'm making my first watchface and everything works fine except the preview. (I've used 1.4.1 version)
I have no clue why but my preview, png and gif, are "zoom in". (I'm on windows 10 if it matters)
I'm pretty sure that this problem happened after I used indexed color (but no idea if it is related)
This doesn't affect the preview I got directly from the bin file. (preview's displayed correctly when i upload the bin file on an Android app, it only affect the png & gif files generated by the software when building the bin file on windows 10)
Is it something well-known ? (that's no biggie but if i do something wrong that I can easily fix by myself, I would do it)
Thanks for your help ! :)
Avatar do usuário
lumenvindex
Contato:
Kierian escreveu: 11 Out 2019, 08:40
It happens because your images have other than 96 DPI resolution. This issue should be fixed in the next version of the tool.
MESS WITH THE BEST
DIE LIKE THE REST
Kierian
Ok, many thanks. :)
infernalcombustion
Registrado em: 11 Out 2019, 14:58
Contato:
Mensagem por infernalcombustion »
Is it possible to have both Linear and Circle displays under StepsProgress at the same time?
I made a skin that uses both, the .bin file was created with no error, and the animated sample displays both the Circle and Linear tracker changing. But when I actually put it on my Mi Band, only the Circle tracker changes, and the Linear one doesn't change from the default state.
Avatar do usuário
lumenvindex
Contato:
infernalcombustion escreveu: 11 Out 2019, 15:03
No. Because...
MESS WITH THE BEST
DIE LIKE THE REST
infernalcombustion
Contato:
Ok, well that's disappointing.
Is it possible to correlate either the Linear or Circle trackers under a different value like Distance or Calories instead?
Avatar do usuário
lumenvindex
Contato:
infernalcombustion escreveu: 12 Out 2019, 23:17
Yes and No.
We cannot change correlation, at least not on a watchface level.
But Distance and Calories values are derived from the Steps value. And hence they are all correlated.
MESS WITH THE BEST
DIE LIKE THE REST
technofab
Registrado em: 13 Out 2019, 10:11
Contato:
Mensagem por technofab »
2 questions:
a) where I can find all XML Specifications and possibilities? Thanks in advance.
b) the sintax must be the same as other app? So unpack with WatchFace.exe -size120x240 band.bin and pack with WatchFace.exe -size120x240 band.json commands???
Avatar do usuário
lumenvindex
Contato:
technofab escreveu: 15 Out 2019, 08:38
a) It's JSON, not XML. Haven't seen any relevant specs in english. Got this thing:
english.zip
(2.58 KiB) Baixado 251 vezes
but some sections have changed their syntax since then (you can learn about some of the changes in README file).
b) Unpack with WatchFace.exe band.bin and pack with WatchFace.exe band.json.
MESS WITH THE BEST
DIE LIKE THE REST
technofab
Contato:
Sorry you are right, is JSON, rofl :D
Thanks for the documentation!
headgamer
Mensagem por headgamer »
So I follow these instructions, drag the .bin file to the .exe file... a DOS window pops up and starts unpacking everything and generating previews... then the window disappears. Nothing. I don't have any window or anything showing unpacked files. What am I doing wrong here? I am using the latest version of the app here in this thread.
-Sean
Avatar do usuário
lumenvindex
Contato:
headgamer escreveu: 22 Out 2019, 22:52
That's it, the program only unpacks the binary to nearby folder. If you have C:\Watchfaces\keanu.bin it will be unpacked to C:\Watchfaces\keanu\.
MESS WITH THE BEST
DIE LIKE THE REST
steak
Mensagem por steak »
Can someone tell me how to perform the step 6 with an iPhone ?
hyippiemon
Registrado em: 16 Ago 2019, 04:05
Contato:
Mensagem por hyippiemon »
the time delimiter isn't working on my band on the old firmware 1.0.5.66!
The preview gif shows the symbol, on the band it isn't shown.
I tried my own watchface (in development) and this one: https://amazfitwatchfaces.com/mi-band-4/view/7989
Please review this!
Thank you!
Avatar do usuário
lumenvindex
Contato:
hyippiemon escreveu: 26 Out 2019, 12:16
This feature works on more recent firmwares only. There is nothing else you can do about it but update the band.
MESS WITH THE BEST
DIE LIKE THE REST
hyippiemon
Contato:
thanks, then I use the old method by integrating in the background
CydPL
Registrado em: 27 Out 2019, 10:13
Contato:
Mensagem por CydPL »
Hi!
Thank you for your work!
Thanks to you I just prepared watchface exactly as I wanted to have.
I woud like to report a minor bug in generating animated gif.
StepsProgress > SolidImage is generated just like I would think it works (and I thought it was), but in miband it works just an opposite way.
So it is not covering background from start to end, but in fact it is fading from start to end along with progress (interesting choice from mi developers).
You can check it in watchface uploaded by me with gif generated by your tool.
https://amazfitwatchfaces.com/mi-band-4/view/8540
Anyway. It is great that someone commits his free time to do stuff like that :)
Regards,
Cyd
geocool
Mensagem por geocool »
I found the source code of AmazfitBipTools but I can't find the source code of MiBandWFTool.
Is it uploaded somewhere ?
ValeCrafter
Mensagem por ValeCrafter »
Hey guys
I have a problem with the animation.
The animation don't run on the Mi Band 4. In the gif the animation runs normaly.
But as soon as I sync the watch face with my Mi Band 4 it stays still.
Do someone knows what to do with this problem?
Kind regards
ValeCrafter
Anexos
GIF
GIF
Space Vale.gif (24.62 KiB) Exibido 12790 vezes
Space Vale.bin
bin
(135.6 KiB) Baixado 137 vezes
The animation code as png
Avatar do usuário
lumenvindex
Contato:
ValeCrafter escreveu: 02 Nov 2019, 16:28
it stays still.
Current MiBand firmware plays animation only when Speed parameter isn't less than 4.
MESS WITH THE BEST
DIE LIKE THE REST
franluciani
Registrado em: 04 Out 2019, 16:55
Has thanked: 9 times
Been thanked: 6 times
Contato:
Mensagem por franluciani »
Hi!
I'm having problem with the hours, tens and ones.
I want move to the right the numbers of "tens" everytime that "ones" show the number 1. For example:
_1_0
__11
_1_2
_1_3
I tried adding the number 1 of the "tens" in the number 1 of the "ones" but when the "tens" show 2 it looks bad. I tried too add black into the "ones" to cover the "tens" and it not work for all numbers.
I'm creating the watch face of Apple (numerals duo, numerals mono (numbers arabic and roman). The only thing that left to give that it looks same is it. If i can solve this, i will upload all the apple faces that i' creating.
Please if anybody can help me, i will appreciate it very much
nite
Mensagem por nite »
Can someone tell me which folder to put the modified .bin file into? :/
Unfortunately, the "corresponding directory " part of this message means nothing to me. "Copy the newly generated bin file to the corresponding directory of the mobile phone"
Responder
Quem está online
