Amazfit watchfaces Tool
JotaEme
Post by JotaEme »
Hi, first time posting. This is an amazing community! I got my Verge Lite just a week ago and I already am making lots of progress just lurking around.
I'm designing my wf and I'm facing a problem with the mini seconds handle, I hope you guys can help.
This is the preview generated by Amaztool 0.1.0.12:
This is the result. I'm aware the color issue is a known problem, but I don't know if the missing seconds handle is caused by this, or it is not being rendered at all.
This is the result with [mention]afwafwafw[/mention] 's py tool. The seconds handle is centered on the whole face, instead of the smaller circle for it.
Can this be solved, using either tool?
Edit: Tried Amaztool again with a completely black seconds handle, and it renders in the middle of the whole watchface, just like with the py version.
NicKoehler
Post by NicKoehler »
How do I add calories on json for the amazfit GTR? I can't find the correct structure
manelto
Post by manelto »
JotaEme wrote: 09 Sep 2019, 13:19
This is the result with @afwafwafw 's py tool. The seconds handle is centered on the whole face, instead of the smaller circle for it.
With the @afwafwafw application you can do what you intend to do. Look at the following code example:
"Seconds": {
      "unknown1": 0,
      "unknown2": 0,
      "unknown3": {
        "X": 0,
        "Y": 120
      "unknown4": {
        "X": 0,
        "Y": 0
      "CenterImage": {
        "X": 4,
        "Y": 64,
        "ImageIndex": 14
You can see the unknown3 tag, with the x and y coordinates. These numbers represent the displacement from the center of the sphere. In this example, the second handler is in the center of the horizontal axis but on the vertical axis it is 120 pixels below the center of the sphere.
manelto
Post by manelto »
NicKoehler wrote: 10 Sep 2019, 16:36
An example from the @afwafwafw app:
"Activity": {
    "Calories": {
      "TopLeftX": 110,
      "TopLeftY": 280,
      "BottomRightX": 179,
      "BottomRightY": 296,
      "Alignment": "TopRight",
      "Spacing": 1,
      "ImageIndex": 13,
      "ImagesCount": 10
NicKoehler
manelto wrote: 10 Sep 2019, 20:08
"Activity": {
    "Calories": {
      "TopLeftX": 110,
      "TopLeftY": 280,
      "Spacing": 1,
      "ImageIndex": 13,
      "ImagesCount": 10
I tryed this method but calories doesn't shows.
I also tryed unpacking some watchface with calories and pack again without make changes and the calories value is vanished..
There are some issue just in the preview?
JotaEme
Post by JotaEme »
manelto wrote: 10 Sep 2019, 20:03
"Seconds": {
      "unknown1": 0,
      "unknown2": 0,
      "unknown3": {
        "X": 0,
        "Y": 120
      "unknown4": {
        "X": 0,
        "Y": 0
      "CenterImage": {
        "X": 4,
        "Y": 64,
        "ImageIndex": 14
Thank you, but this is exactly what I have:
  "AnalogDialFace": {
    "Seconds": {
      "unknown1": 0,
      "unknown2": 0,
      "unknown3": {
        "X": 0,
        "Y": 132
      "unknown4": {
        "X": 0,
        "Y": 0
      "CenterImage": {
        "X": 7,
        "Y": 35,
        "ImageIndex": 3
It renders like this:
manelto
Post by manelto »
One thing is that what you see on the PC and a different one is what you see on your watch
jlsh007
Post by jlsh007 »
I've managed to unpack my bin file, replaced the png file for the background as the color is incorrect after unpack, replaced my clock hands png file, pack it again. But when i try to upload to my GTR watch it said invalid.
It works when i just unpack and replace the background png, then pack it again without changing the clock hands png.
I just want to change the clock hands image. Any other solutions?
manelto
Post by manelto »
jlsh007 wrote: 12 Sep 2019, 06:28
My experience tells me that when I try to upload a file larger than 2 megabytes, it gives me problems.
Is the result of the new file larger than that size?
fx_advanc
Has thanked: 7 times
Post by fx_advanc »
same with mine, adjusted to exact coordinate but end up at the center of it. must be watch doesnt enable the seconds handles.
JotaEme
Post by JotaEme »
manelto wrote: 11 Sep 2019, 13:41
I know, I already showed on my first post what it looks like on the watch, and it is exactly the same!
gid12
Post by gid12 »
When I pack back to bin file why color display wrong? I use Amazfit GTR.
manelto
Post by manelto »
JotaEme wrote: 12 Sep 2019, 13:12
I don't know how you make it but to me is working. An extreme example with not one but three handles discentered: https://amazfitwatchfaces.com/gtr/view/472
The code:
  "Background": {
    "Image": {
      "X": 0,
      "Y": 0,
      "ImageIndex": 0
    "Preview": {
      "X": 0,
      "Y": 0,
      "ImageIndex": 1
  "Date": {
    "MonthAndDay": {
      "Separate": {
        "Day": {
          "TopLeftX": 207,
          "TopLeftY": 25,
          "BottomRightX": 247,
          "BottomRightY": 50,
          "Alignment": "Center",
          "Spacing": 4,
          "ImageIndex": 2,
          "ImagesCount": 10
      "TwoDigitsMonth": true,
      "TwoDigitsDay": true
  "Battery": {
    "Scale": {
      "CenterX": 227,
      "CenterY": 227,
      "RadiusX": 30,
      "RadiusY": 0,
      "StartAngle": 0,
      "EndAngle": 360,
      "Width": 4,
      "Color": "0x00FFD800",
      "Unknown9": 180
  "Activity": {
    "Calories": {
      "TopLeftX": 295,
      "TopLeftY": 325,
      "BottomRightX": 350,
      "BottomRightY": 330,
      "Spacing": 1,
      "ImageIndex": 2,
      "ImagesCount": 10
    "Pulse": {
      "TopLeftX": 295,
      "TopLeftY": 355,
      "BottomRightY": 380,
      "Spacing": 1,
      "ImageIndex": 2,
      "ImagesCount": 10
    "Distance": {
      "Number": {
        "TopLeftX": 300,
        "TopLeftY": 255,
        "BottomRightX": 360,
        "BottomRightY": 270,
        "Spacing": 1,
        "ImageIndex": 2,
        "ImagesCount": 10
      "SuffixImageIndex": 14,
      "DecimalPointImageIndex": 13
    "Steps": {
      "Step": {
        "TopLeftX": 280,
        "TopLeftY": 290,
        "BottomRightY": 320,
        "Spacing": 1,
        "ImageIndex": 2,
        "ImagesCount": 10
  "StepsProgress": {
    "Circle": {
      "CenterX": 320,
      "CenterY": 315,
      "RadiusX": 78,
      "RadiusY": 0,
      "StartAngle": 0,
      "EndAngle": 360,
      "Width": 3,
      "Color": "0x00FF0000",
      "Unknown9": 180
  "AnalogDialFace": {
    "Hours": {
      "unknown1": 0,
      "unknown2": 0,
      "unknown3": {
        "X": -89,
        "Y": -89
      "unknown4": {
        "X": 0,
        "Y": 0
      "CenterImage": {
        "X": 10,
        "Y": 72,
        "ImageIndex": 12
    "Minutes": {
      "unknown1": 0,
      "unknown2": 0,
      "unknown3": {
        "X": 93,
        "Y": -89
      "unknown4": {
        "X": 0,
        "Y": 0
      "CenterImage": {
        "X": 10,
        "Y": 72,
        "ImageIndex": 12
    "Seconds": {
      "unknown1": 0,
      "unknown2": 0,
      "unknown3": {
        "X": -88,
        "Y": 89
      "unknown4": {
        "X": 0,
        "Y": 0
      "CenterImage": {
        "X": 10,
        "Y": 72,
        "ImageIndex": 12
manelto
Post by manelto »
You must work with this tool: https://github.com/ghtalpo/py_amazfit_tools
manelto
Post by manelto »
gid12 wrote: 13 Sep 2019, 08:31
Horatius80
Post by Horatius80 »
Are there any news about unpacking the newest Watchfaces from Amazfit GTR ... there are new components like Weather, and separated month... but I can not to manage out how to decompile this new watchfaces :(
mobius
Post by mobius »
hi guys, is there a tool that allows you to read the changes to *json? Every time I make a change I have to generate the package with AmazTool and look at the *gif created. Is there a faster way to see the effects of json changes? Thanks
jjc
Post by jjc »
how to use python to make a binary file from json please?
With amaztools i have a color problem !!!
jjc
Post by jjc »
if you a have color problems, i found a tool in GitHub called py_amazfit_tools-master.
in release folder decompress amazfit_gtr_tools_win32
drag your json or bin file to main and thats it
rawraw
Post by rawraw »
I have a problem with a BIP watchface that I downloaded in .bin format. If I unpack it and immediately repack it I lose the analog clock... I first thought I made some error during editing the watchface but it turns out this program seems to have some strange problem with this watchface.
Its this WF https://amazfitwatchfaces.com/bip/view/25608
If I send it to my watch it looks good.. but If I use this program to un- and repack it wont work...
Any suggestions?
The .gif looks so perfekt..
I zipped my small project:
Bip.zip
(255.14 KiB) Downloaded 356 times
Horatius80
[mention]rawraw[/mention]
I always used this for BIP´s Watchfaces and I had no issues:
https://bitbucket.org/valeronm/amazfitb ... 1.0.3.1.7z
http://www.mediafire.com/file/941xpc8ef ... 9.zip/file
rawraw
Post by rawraw »
Horatius80 wrote: 15 Sep 2019, 04:50
@rawraw
https://bitbucket/valeronm/amazfitbipto ... 1.0.3.1.7z
http://www.mediafire/file/941xpc8efce45 ... 9.zip/file
I have been using AmazfitBipTools in 1.0.3.1 from bitbucket.. But it fails to repack a file that I never even touched..and if I modify something the preview gif is perfect as you can see in my zip.. But no work on watch..
ataru
Post by ataru »
quite same issue here.
https://amazfitwatchfaces.com/verge-lite/view/264
in the preview it's all ok, but when i flash, background turns blue, no digit is shown and hour and minute hands are centered in dial and not 25 pixele up:
what's wrong with it?
jjc
Post by jjc »
hello,
somebody know how to have an analog view for battery? instead of numbers i'd like watch hands
for amazfit gtr.
Tks !!!
JotaEme
Post by JotaEme »
manelto wrote: 13 Sep 2019, 11:38
I guess it works differently on the Verge Lite... fx_advanc has the same issue! I installed his watch directly from the Android app and it has the same behaviour.
Description
Nomoz-Blue
Originality from el_boda - /gtr/view/403
Repacked & Readjust dial version
Bug: Animation doesnt same as actual position.
