Amazfit WatchFaces APP (iOS) open BETA
Has thanked: 1105 times
Been thanked: 266 times
Finally we waited for this!
AmazFace Beta is available.
Get ready for bugs!
AmazFaces BETA for iOS
Luiz Fraga
Post by Luiz Fraga »
Hello GIK-Team team, I was very excited about the news of the AmazFaces app for iOS, I would like to receive an invitation to test BETA on TestFlight as long as it does not pose any risk of smart watch loss. I am Brazilian and I have an Amazfit Verge Lite. Congratulations for the excellent work. It's wonderful what they are doing.
jparr
Post by jparr »
Hello Luiz
Just download TestFlight to your iPhone.
Open this page in your iPhone Browser and follow the link to download AW App.
It's that simple.
After installation you'll see a red dot near the App name and if you open TestFlight you'll see the Apps name.
The App seems to be working fine but how to install the faces is another problem...
When I press download it just opens the Files App.
I think I'm missing something... :idea: ???
Luiz Fraga wrote: 05 Sep 2019, 14:47
No any risk of smart watch loss at this moment.
Luiz Fraga
Em Português BR
- Obrigado Jparr. Fiz o que disse e já estou acessando o aplicativo de testes, porém, como você mesmo mencionou, ao clicar em Download, apenas abre o app Arquivos, não salvando em lugar algum. Tentei até apontar para a pasta do Amazfit, mas não ele não descarregar o arquivo na pasta. Aos desenvolvedores, fica a dica.
In English
- Thank you Jparr. I did what I said and I'm already accessing the test app, but as you mentioned yourself, clicking Download just opens the Files app, not saving anywhere. I even tried to point to the Amazfit folder, but it didn't unload the file into the folder. For developers, is the tip.
jparr wrote: 05 Sep 2019, 15:09
Hello Luiz
It's that simple.
Luiz Fraga
Em Português BR
[*]Consigo trocar as Watch Faces baixando via Safari pelo iPhone, salvando no aplicativo Arquivos, na pasta da Amazfit/watchSkin/[alguma_pasta_já_disponível], renomeando o arquivo baixado para o mesmo nome dessa pasta. Acessando o app Amazfit, e sincronizando com a watchface correspondente a aquela pasta que você jogou o arquivo. Não sei se me fiz entender, mas existe este modo para trocar sua watch faces pegando as daqui do site.
In English
[*]I can change Watch Faces by downloading via Safari via iPhone, saving it in the Files app in the Amazfit / watchSkin / [some_folder_available_folder] folder, renaming the downloaded file to the same name in that folder. Accessing the Amazfit app, and syncing with the watchface corresponding to that folder you played the file. I don't know if I made myself understood, but there is this way to change your watch faces taking the ones from here.
Hello Luiz
It's that simple.
Ekueku
Post by Ekueku »
Ciao ragazzi .. mi potete aiutare? Non riesco ad installarle ... qualcuno mi può aiutare .
Inviato da iPhone
Ekueku wrote: 21 Sep 2019, 19:23
Inviato da iPhone
Describe in more detail, please!
Riccardo57
Post by Riccardo57 »
Hi GIK-Team,
I just installed the beta and immediately tested it.
I was really excited about the news of the AmazFaces app for iOS, because I was hoping that this beta would solve a serious problem that afflicts me since the penultimate Update of the AMZFIT App: The AMAZFIT folder is no longer present, preventing me from carrying out any installation of new WatchFaces.
Unfortunately, the situation remains unchanged.
Fortunately on my iPad I still have the old version of AMAZFIT App, the AMAZFIT folder is immediately visible there and therefore everything works perfectly, so when I really want to change I use it, but it is certainly not very practical.
Please let me know
Riccardo
osmat
Admin
Has thanked: 35 times
Been thanked: 73 times
Post by osmat »
For a successful installation, you need to enable the visibility of the device in Amazfit, wait for synchronization and try again.
pacharico
Post by pacharico »
Hola:
Podrías invitarme para la app en iOS?
Gracias.
Perdona no escriba en inglés.
osmat
Admin
Post by osmat »
pacharico wrote: 06 Feb 2020, 13:11
Hola:
Gracias.
https://apps.apple.com/app/amazfaces/id1462259687?l
mahesoo
Post by mahesoo »
hello i'm using latest amazfaces app in IOS and always failed to sync watchfaces in verge lite is there any solution ?
osmat
Admin
Post by osmat »
mahesoo wrote: 16 Mar 2020, 22:27
Turn on device visibility in Amazfit Wait for synchronization and try installation
abcd840322
Post by abcd840322 »
Hello
When will mi band 5 version release? I discovered that install watch faces through Amazfit encounters problems of battery indicator not functioning (remain 100% regardless the actual capacity)
abcd840322 wrote: 02 Aug 2020, 03:52
Hello
We plan to launch it next week.
fritz_inferno
Post by fritz_inferno »
no support mi band 5?
fritz_inferno wrote: 17 Sep 2020, 10:37
We are working on it.
wing0826
Has thanked: 9 times
Post by wing0826 »
Hi!~
can amazfitwatchface support ZEPP-E / GTR2 ?
wing0826 wrote: 22 Sep 2020, 07:20
Hi!~
Hi. We do not have information on them yet.
darlyanne
Post by darlyanne »
Gente, alguem poderia me falar o passo a passo de como fazer? Não estou conseguindo.... Eu ja faço uso do TestFlight em outros app. Mas no AmazFaces, não vai.
Perico
Post by Perico »
Hola a todos, tengo un T-REX 2 y me he instalado la App en mi iPhone 12 pero no se como instalar las feces en el reloj, me podéis decir como se hace o decirme donde hay un manual?. Gracias
Return to “AmazFaces app”
