GTR Face Functionality
davidcheok
Post by davidcheok »
My eyesight is failing me hence why i bought the GTR. However there isnt much faces that fit the needs of older folks like us. What we need:
1) Day and Date (should be clearly readable, many are too small)
2) Time (Digital preferably but analog ok if visible - note: most ive seen blocks out the other info at certain times)
3) Weather
4) Battery Charge
5) Heart Rate
6) Steps (optional)
7) Calories (optional)
8) Compass Dial (as the surround if it doesnt take too much power)
9) Barometric Pressure (why not? Watch has it)
Hope someone out there is creative enough to do this.
cloporte
Post by cloporte »
Same case for me,
i noticed that many wf are using the name of the day we are ... why it's wasting much space ?
i dont even need the month just the date Day N-numver
regarding heart rate you can set up a threshold when you will be alerted if your heart is beating too fast
while you are not doing any particular effort .
Battery is a must even if it's a long running one here .
TopS
Post by TopS »
I tried puting together something you might be able to use.
A few notes:
Weather does not seem to be available on the GTR watchface (worked on the bip so it's a bit strange)
Same goes for compass and barometric pressure ( these were not on the bip either )
I'll upload the previews here so you can take a look, if you want something changed and it's possible I'll try to make it happen.
Once we have a 'final version' you like I'll upload the watchface and put the link here so you can download it.
Preview images:
TopS
Post by TopS »
Well... if anyone wants it here is the link for it: https://amazfitwatchfaces.com/gtr/view/317
davidcheok
Thank you for your consideration and efforts.
The Amazfit fit app has two faces with weather functionality and the info fits what i need but its too small to read. Hahaha.
Night spirit and Military Camo.
Its strange that the BIP has easy access to temperature and weather but not GTR.
I hope over time, you creative people out there will do what you do best and churn out some wonderful masterpieces.
Keep up the brilliant effort and output.
TopS
Post by TopS »
As it turns out there are differences in the .bin file for the GTR other than the resolution so until the people making the pack/unpack tools figure out how to make that work there is no way to do it.
I'll make a weather version as well once the tools support it.
Codeblack
Post by Codeblack »
ist eine bischen kleinere variante auch möglich ?
fx_advanc
Has thanked: 7 times
Post by fx_advanc »
davidcheok wrote: 29 Aug 2019, 03:18
3) Weather
4) Battery Charge
5) Heart Rate
6) Steps (optional)
i think you guys should realize once the official watchface have all these features, then you can readjust n enabled all kind of element,
as for now, we are waiting for firmware update as they enable it.
wapid
Post by wapid »
Great and legible ... Please add some color to the icons. It is also worth making variations of this dial with these large numbers. Thank you for your work.
Don MC
Post by Don MC »
wapid wrote: 19 Sep 2019, 14:31
Yes. With seconds and minus the heartbeat, please. Great for a half-blind ass like me.
